01 Expedition Keys
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49574
Printed Date: May 15, 2024 at 7:55 PM
Topic: 01 Expedition Keys
Posted By: Ohmz
Subject: 01 Expedition Keys
Date Posted: February 07, 2005 at 4:52 PM
Does anyone know how to program a new master key for this vehicle. The 2 original keys got wiped out.
Posted By: auex
Date Posted: February 07, 2005 at 5:01 PM
Dealer? You could check out Velocity's website, he might have a way listed there.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: harveje
Date Posted: February 07, 2005 at 9:00 PM
IT takes 2 masters to program the rest. If you have 0 or 1 then the sealership or a locksmith with the programmer can do it. Don't let the stealership tell you it takes more than 15 min. because it dont.
Posted By: harveje
IT takes 2 masters to program the rest. If you have 0 or 1 then the stealership or a locksmith with the programmer can do it. Don't let the stealership tell you it takes more than 15 min. because it dont.
Posted By: draasch
Date Posted: February 08, 2005 at 2:20 PM
it will take 1o mins to erase the keys and another 10 mins to program the new ones.......check with a locksmith first...... ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: profuse007
Date Posted: February 08, 2005 at 8:22 PM
same here, i would take it to the locksmith first.
------------- Houston,TX
Posted By: Ohmz
Date Posted: February 08, 2005 at 9:57 PM
The locksmith? They can program the keys?
Date Posted: February 08, 2005 at 11:58 PM
Ilco(key makers) has scanners and programmer out, am sure some locksmith can get a hold of it.
Posted By: draasch
Date Posted: February 08, 2005 at 11:59 PM
yes...i have the SDD programmer...you can do all kinds of transponder keys............ ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: February 09, 2005 at 12:12 AM
hey david,
how are the keys programmed?
on other hand, can you flash(program) the ECU(pretend it didnt come w/ its own key) correspond to another key w/ that Ilco SDD? btw, am askin this due to engine swaps.
Posted By: draasch
Date Posted: February 09, 2005 at 12:29 AM
are you talking about fords????
on the ones that will work with the SDD (ford) i can go in and ask permission to access the transponder system....it takes tem mins. to decide....once in, i can erase all keys...then i can ask again to program a new key...again 10 mins.....once that is done, i can do a second key.....;again 10 mins....after i have two keys done, the rest are done without the programmer.....
there is a "flashing programmer" for the toyo's but a dont have one of those......they cost a couple grand..... ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: February 09, 2005 at 12:54 AM
ic, SDD only design for certain cars like ford. gotcha
man, i guess those stuff do cost a lot.
