Please help - Need horn lesson...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49709
Printed Date: March 27, 2026 at 9:52 PM
Topic: Please help - Need horn lesson...
Posted By: Mike_89gts
Subject: Please help - Need horn lesson...
Date Posted: February 09, 2005 at 10:40 AM
ok - I'm still trying to figure out how this works and what wire I'm looking for on my 89 Celica GTS to hook the 500ma - horn output wire to on my RS system to.
So, I have a little wire in my steering wheel that when grounded blows the horn.
I've read that there's a metal ring behind the steering wheel that's connected to that little green wire - so when you ground that ring - the horn also blows.
Now, - my question is this. I only have 3 wires that connect to that copper ring. None are the colors I've been reading (green or GREEN/ blue).
So - I'm gonna check with my trusty DMM but what am I looking for exactly? - Is this wire going to read +12v??? - What's it suppose to do when I blow the horn? - And this is the wire I'm suppose to hook the 500ma - output directly to?
Please help me. - This is my last wire and I'm confused. :(
Mike ‘89GTS
Posted By: mo12v
Date Posted: February 09, 2005 at 10:59 AM
Not sure why you are at the Horn ring..............
The wire you are looking for is in harness on steering column.......It will show Negative when you press horn button.
Yes, U can hook wire from RS unit to Horn wire, but I have seen some need a Relay to supply a stronger ground.
MO
Date Posted: February 09, 2005 at 11:15 AM
thanks for your time mo12v.
I was looking for a wire running along the bottom
of the steering shaft housing. - all of the wires
plug into a harness at the end of the shaft before
entering the firewall. - Are you saying the wire can
be found on the other side of that connector?
??? - Is that correct?
Wouldn't there have to be a wire that carries the ground from the steering wheel to this harness?
That's why I'm at the horn ring 'cause I'm looking for the wire that takes the ground from the steering wheel and runs down the column and there's no GREEN/ blue - there's only a solid greenish blue and a thin guage green wire but both show ground with no horn pressed.
Thanks again MO
Mike ‘89GTS
Posted By: thepencil
Date Posted: February 09, 2005 at 11:16 AM
Horn Trigger green    -   steering column
If you don't find the green wire then you are not looking in the right spot. This is when a good safe test is so useful.
Yes, you can hook the horn wire directly to the green wire once you find it.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: February 09, 2005 at 11:30 AM
So with no horn pressed this wire shouldn't register as anything right? - Only negative when the horn's pressed - right?
Thanks folks. - Truly appreciate it.
Mike ‘89GTS
Posted By: mo12v
Date Posted: February 09, 2005 at 12:32 PM
Yes & NO.....It could read 2 - 12 Volts or Nothing..........with NO horn pressed
Use OHM Meter and Meter the wire you find (below steering column, coming out of steering column)....Press Horn.....Check reading.
MO
Date Posted: February 09, 2005 at 6:01 PM
Got it guys! - Thanks.
The horn wire on my 1989 Toyota Celica GTS is GREEN/ pink.
Now if I can only get the remote start to work.
I think the tach wire might be wrong.
Thanks again!
Mike ‘89GTS
