05 pathfinder schematics
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49923
Printed Date: May 06, 2026 at 9:59 PM
Topic: 05 pathfinder schematics
Posted By: desh187
Subject: 05 pathfinder schematics
Date Posted: February 11, 2005 at 10:42 PM
has anyone installed an autostart to an 05 nissan pathfinder,any info is appreciated.thanks. posted_image
Posted By: thepencil
Date Posted: February 11, 2005 at 10:52 PM
DIRECTWIRE™ WIRING INFORMATION - NISSAN / PATHFINDER / 2005 / Remote Start
[PRINT THIS PAGE]
12volts      green (40A)       +       ignition harness
Starter      gray       +       ignition harness
Second Starter      lt. green       +       ignition harness
Ignition      WHITE/ green       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      red       +       ignition harness
Second Accessory      GREEN/ YELLOW       +       ignition harness
Keysense      black       +       ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is to the right of the steering column.
Power Lock      lt. green to purple       -       driver kick or BCM, pin 45
Power Unlock      white to lt. green       -       driver kick or BCM, pin 46
Lock Motor      purple       5wi      driver kick or BCM, pin 65
Unlock Motor      gray       5wi      driver kick or BCM, pin 59
Parking Lights+      gray       +       driver kick, harness to rear
Parking Lights-      N/A
Hazards      green       -       hazard switch or BCM, pin 29
Turn Signal(L)      lt. green       +       driver kick or BCM, pin 60
Turn Signal(R)      green       +       passenger kick or BCM, pin 61
Reverse Light      lt. blue       +       driver kick, harness to rear
Door Trigger      see notes       -       BCM
Notes: The LF door is gray in pin 47. The RF door is lt. green in pin 12. The LR door is pink in pin 48. The RR door is blue in pin 13. Use all four wires and diode isolate each.
Dome Supervision      brown       -       driver A pillar or BCM, pin 63
Trunk/Hatch Pin      yellow and lt. green (glass)       -       driver kick or BCM, pins 43 and 42
Notes: Use both wires and diode isolate each.
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      lt. blue       -       driver kick or BCM, pin 8
Notes: Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors.
Factory Alarm Disarm      RED / white to gray       -       driver kick or BCM, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder. This wire will also unlock the doors with a double pulse.
Disarm No Unlock
Tachometer      NOT WHITE/ green       ac       any fuel injector
Wait to start      N/A
Brake Wire      yellow       +       brake pedal switch or driver kick
Parking Brake      green       -       parking brake sw. or cluster, pin 31
Horn Trigger      brown       -       horn switch
Memory Seat 1      lt. GREEN/ black to lt. green       -       driver kick or ADPCU, pin 9
Notes: The ADPCU (Automatic Drive Positioner Control Unit) is above the driver kick.
Memory Seat 2      pink/blue to pink       -       driver kick or ADPCU, pin 25
Memory Seat 3      N/A       -
Immobilizer Bypass Module:      Required: Yes      Type: Transponder      Part #: 556U or 555U
Notes: Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
