Remote start alarm question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49930
Printed Date: May 07, 2026 at 1:33 AM
Topic: Remote start alarm question
Posted By: slush
Subject: Remote start alarm question
Date Posted: February 12, 2005 at 12:40 AM
Hey,
My remote start has two YELLOW wires (igition).  One is a 12 gauge 12v+ OUTPUT wire connected to one of 4 relays in a block of relays that came with the alarm, and the other is also yellow, but on a different connector, but it is ignition INPUT.  Here is the word-for-word description of both:
6-Pin Starter Harness
Pin 5 YELLOW: Ignition Output (+). Connect to the main ignition wire that provides +12V when the ignition
is on and while cranking the starter.
16-pin main harness
Pin 6 YELLOW : +12V Ignition Input. The Yellow wire must connect to a main ignition wire at the ignition
harness. This wire must show +12V when the ignition is on and while cranking the starter. The voltage
must not drop when the car is starting.
Do i just connect these wires together and to my ignition wire?
-Derek
Posted By: slush
Date Posted: February 12, 2005 at 12:45 AM
also this alarm system has 3 power inputs:  2 supply power to the block of 4 relays, and 1 supplies power to the brain.  The manual highly recommends not to, but could i chain them together and just tie them to one power wire?  I dont know of any other separate power wires under my dash.  I have a 1993 Mitsubishi Diamante ES, by the way.  Thanks!
-Derek
Posted By: draasch
Date Posted: February 12, 2005 at 7:36 AM
what brand of unit are you using????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: slush
Date Posted: February 12, 2005 at 8:20 AM
scytek...
Posted By: slush
the manual can be found here:
https://www.scytek.net/pdf/Astra4000RS.pdf
Posted By: slush
Date Posted: February 12, 2005 at 1:01 PM
anyone know how i hook up these two wires?
-Derek
Posted By: iskidoo
Date Posted: February 13, 2005 at 11:36 AM
Yes, connect both the Ignition 1 relay output and the +12V Ignition Input to the
Ignition BLACK/ white (+) steering column
You don't need the BROWN 2nd ignition output. That is for other vehicles that sometimes have 2 or 3 Ignition wires that need to be energized during remote start. Just tape the output for Ignition 2 off and do not use.
Yes, you can tie the 3 power wires to the
12volts red (+) steering column
This link will show you all the wire colors and locations for your vehicle.https://directechs.com/directwire/wire_body.asp?action=select&yr=32&product=Remote%20Start
Good Luck, Steve
