Diode Question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49944
Printed Date: May 07, 2026 at 5:34 AM
Topic: Diode Question
Posted By: Forseti
Subject: Diode Question
Date Posted: February 12, 2005 at 9:55 AM
What would make a Diode get so hot it burns the plastic on the croimp connectors and turn them green ?
Posted By: jazzy95tsi
Date Posted: February 12, 2005 at 11:03 AM
Too much currentposted_image
Jeff posted_image
Posted By: profuse007
Date Posted: February 12, 2005 at 12:32 PM
bad crimping or loose crimping.
Houston,TX
Posted By: Jschult3
Date Posted: February 12, 2005 at 3:43 PM
All of the above.
RU using 1n4001 or equivalent and is it a 1 amp circuit?
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
Posted By: Forseti
Date Posted: February 14, 2005 at 10:57 AM
Yes its a 1N4001 and its in the parking light circuit ... the one that came with the alarm burned and now this one .... I cant figure it out
Posted By: Forseti
Date Posted: February 14, 2005 at 12:38 PM
A local car alarm place gave me a 1N5401 diode to use ..... can I use this ?
Date Posted: February 14, 2005 at 5:02 PM
Yes the 1N5401 is rated for 3 Amp instead of ! Amp.
Jeff posted_image
Posted By: Forseti
Date Posted: February 15, 2005 at 5:08 PM
Now I have people telling me not to install a diode ... to just connect without it .... would leaving it out cause any problems ?
Posted By: iskidoo
Date Posted: February 15, 2005 at 9:30 PM
The output from most Alarm/remote start/keyless entry units is typically rated at 10amps so i wouldn't think you even need the diode. What year/make/model is the vehicle?
Posted By: Forseti
Date Posted: February 16, 2005 at 5:14 PM
Its a 99 Dodge Dakota ... Also its a Clifford Avantguard 4 alarm
