key sense wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5032
Printed Date: June 01, 2024 at 10:24 AM
Topic: key sense wire
Posted By: ericw
Subject: key sense wire
Date Posted: November 01, 2002 at 5:18 PM
Does anyone know, do I have to hook up the key sense wire for my IPPME module on a 2002 chev silverado? The directions say "hook up only if keysense wire shows a ground when the doors are closed and the key is in the ignition" If so where do I find them and what color are they? Also when I am done programming my IPPME module when I start the vehicle and let it run for at least 10 seconds do I have to remove the programming jumper on the IPPME module?
Posted By: Chris Luongo
Date Posted: November 01, 2002 at 7:10 PM
None of the Passlock modules I've ever used has needed a key sense hookup...if yours does, I'd return it and buy something that's designed intelligently. In any event, most GM key sense wires are green, and negative trigger. I've never had occasion to look for this wire before, but the simplest way would be to remove the plastic shroud from the steering column, and test each wire that you see coming from the key cylinder.
Posted By: Velocity Motors
Date Posted: November 01, 2002 at 7:33 PM
There is a smaller guage GREEN wire running along side with the other ignition wires that is the keysense wire. You will only need to use this if the above is true. Leave the jumper in place after the programming is complete.
------------- Jeff
Posted By: phqyouazzhol187
Date Posted: February 18, 2003 at 3:37 AM
is there anyway to bypass the key sense wire on a 2001 ford taurus other then buyin the mod? And what color wires are they? the dealer said that it sould be a pink and black wire on the right side of the dash, but i could not find one on mine, my car doesnt even start, this is after trying to install a remote started. i put things back to the way they were and still does not start, all fuses are good, dont know about the relays, let me know thankx!
Posted By: jrilla
Date Posted: February 18, 2003 at 9:09 AM
phqyouazzhol187, you should start a new topic for the problem you are having; this way you will get a better response. You should also provide us with more detail, likw what starter you installed and how did you try to bypass the transponder anti-theft system? When you say it doesn't start, do you mean that it wont start when you try to remotely start it, or when you use the key?
------------- J Rilla
Owner/Installer
