04 BMW 525, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50703
Printed Date: April 29, 2024 at 12:36 AM
Topic: 04 BMW 525, remote start
Posted By: 5150azn
Subject: 04 BMW 525, remote start
Date Posted: February 23, 2005 at 6:47 PM
I need diagram for this car as well as any info and tips you guys can get me. Thanks in advance!
------------- Tell the Snap-On guy I'm not here!
Posted By: cutter1122
Date Posted: February 23, 2005 at 7:51 PM
Posted By: 5150azn
Date Posted: February 24, 2005 at 10:57 AM
This diagram says 2003 is it the same as 2004? Has anyone done a remote start on any of these?
Posted By: 5150azn
Date Posted: February 24, 2005 at 11:04 AM
I've already read the thread saying you can't do a remote start on this car. But the Dei diagram looks fairly simple. Whats the deal?
Posted By: mxxmikexx
Date Posted: February 24, 2005 at 12:34 PM
i doubt its simple on an 04 bmw. let us know how it turns out
------------- Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: 5150azn
Date Posted: February 24, 2005 at 5:04 PM
I hope I can get some help from someone. I have to do a demo tomorrow!
Date Posted: February 24, 2005 at 6:07 PM
i just pulled up the 04' from audiovox tech and it seems to be the same as the 03'. as for it not being able to be done...anything is possible, just depends on how much of a pain in the ass its going to be. here is the info for the parking light interface if you dont already have it. let me know how it turns out if you wind up doing it, i am very interested to find out for myself!!!!
bmw parking light interface
if you need tech help on this car, pm me and ill give you some tech support ------------- Mike Battaglia
Posted By: 5150azn
Date Posted: February 25, 2005 at 10:49 AM
aaalright! Todays the day. I'll shut down the whole tech department to do this install if I have to! I'll let you guys know what happens.
(Praying to install gods)<-----
Posted By: 5150azn
Date Posted: March 01, 2005 at 11:08 AM
Ok for all you guys paying attention. We wasted a day trying to install a prototype alarm that didn't work correctly. But other than that the install was fairly straight forward. However we are stuck trying to bypass the transponder system. With the key in the ignition everything works fine. We've used all the different bypass modules we could get our hands on and still noth'in. Did the wire around the key also. Plz help!
My will to make this car submit to my bidding is unmeasurable!
Posted By: Velocity Motors
Date Posted: March 01, 2005 at 1:01 PM
What bypass did you use for the immobilizer ? ( Which ones ? ) Did you get the dei 555b or the factory bmw key ring antenna ?
------------- Jeff
Date Posted: March 01, 2005 at 5:24 PM
is it still the EWSII transponder system? in the new bmw's? what problems did you have with the trans. system? couldnt find the wires going to the ewsII (if thats still the system) ?
Posted By: 5150azn
Date Posted: March 01, 2005 at 8:57 PM
Found the wires. Havent tried the Dei peice yet but tried a different bypass peice. Just got a hold of a 555b or u... also just popped out the chip from the key. Going to try to wrap wire around the chip. You guys think that will work? or better with the 555u? What about the key sense? probably won't be able to get back to it till later this week. But I'll let you guys know whats up.
Posted By: dare_ds69
Date Posted: March 02, 2005 at 7:24 AM
try to get a factory ring from bmw it cost a round $29, in the ring there are a plug, you can use the power locks wires plug, it fits perfect on the ring. and use a relay to interface with the factory ewsII. when you put the key in the ring find a little foam to stockm the key in and taped around that way the key is going to move. there are two wires from EWSII just cut one 86 is 12v+ fused 85 is ground from remote start 87 is going to one wire of the EWSII 87a is going to key side 30 is going to EWSII I did many of those and thas the best way that i found bypass the EWSII good luck ------------- how own your mind, control your life.
MECP certified. always use a DMM
Posted By: 5150azn
Date Posted: March 02, 2005 at 11:16 AM
I saw that but I was worried about spending 30 bucks on something that wouldn't work. Have you guys used a 555b?
Date Posted: March 02, 2005 at 12:50 PM
ive used the 555b but the new 556u does the same thing and its better to keep those in stock anyways instead of specially ordering a 555b just for bmw's, ya know...
Posted By: ccroadshop99031
Date Posted: March 02, 2005 at 1:55 PM
i belive the new 5 series uses EWS II as its anti theft the 555b should work i beleive the new 556u also works usually the stock bmw key wont fit, but the car come w/ 2 standard keys and a black plastic wallet key that works great.
Posted By: 5150azn
Date Posted: March 02, 2005 at 6:32 PM
OK THE VERDICT!!! After 3 days of intense installing and head scratching we are unable to get this 04 525 Bmw to remote start. We have used all relevent dei peices as well as some cheaper ones. Also we busted the key to get the chip; wrapped the chip and used a relay... you know that method. Still unable to get things to work. The only method we have not tried is to use a factory transponder ring. Like I said we were not able to get this car to remote start without the key in the ignition... What do you guys think?
