05 F-150 & bypass, which one?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51332
Printed Date: January 27, 2026 at 10:19 AM
Topic: 05 F-150 & bypass, which one?
Posted By: saleen49
Subject: 05 F-150 & bypass, which one?
Date Posted: March 05, 2005 at 10:01 AM
 Just picked up an 05 FX4 F-150 with pats s-key and narrowed down to pypass 555f or 556u but not sure which is better, getting a spare key from work is not a problem,
 thanks
Posted By: gcote
Date Posted: March 05, 2005 at 10:10 AM
the 556u is the best way to go. the 555f can be a bit of a pain triing to get that pellet in the right spot and still be able to reinstall the column.
turn us on
Posted By: gcote
Date Posted: March 05, 2005 at 10:12 AM
do you already know about the gem module in that truck?
turn us on
Posted By: BNLUIS
Date Posted: March 05, 2005 at 10:21 AM
555F won't work on that truck , use a 556U and a spare key. As far as the GEM module,  it  can sometimes be disable the sleepy locks, read the owners manual, it is called "  door lock Inhibit". But simetimes it not neccesary. Ford stop using that feature on some of their newer models.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: saleen49
Date Posted: March 05, 2005 at 11:01 AM
 Yes,It does have a gem module,
Posted By: saleen49
Date Posted: March 05, 2005 at 11:06 AM
 I installed a Mannix remote/alarm on my 03 Taurus, I assume it has the sleepy locks, works great
Posted By: mxxmikexx
Date Posted: March 05, 2005 at 1:06 PM
forget the dei module, trilogix has a great module that learns the code and you dont lose a key,and you dont even have to tear apart the column shroud.PKF3 is the part# www.transponderbypass.com
the 555f is a joke. DEI is way behind on their interfaces
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
