1994 Accord doorlocks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51342
Printed Date: January 27, 2026 at 10:19 AM
Topic: 1994 Accord doorlocks
Posted By: jaurora
Subject: 1994 Accord doorlocks
Date Posted: March 05, 2005 at 11:39 AM
I did a R/S & key less entry in the car but I only was able to complete half of it. I went off of two tech sheets and for the life of me I could not find the door lock and unlock wires. Both sheets said it was an orange and black white wire. But one said it was in the connector above fuse box and the other said it was in a 2 pin connector taped to the harness above fuse box. I searched and probed around for maore than an hour and could not find a thing. Can someone please help me with the locations of these two wires.
Thanks,
Jeremy
MECP certified (If it really means anything)
Jeremy
Posted By: mxxmikexx
Date Posted: March 05, 2005 at 1:08 PM
its there. just have to look
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: jaurora
Date Posted: March 05, 2005 at 2:02 PM
That really helps!
Jeremy
Posted By: KarTuneMan
Date Posted: March 05, 2005 at 3:01 PM
This will help.....go LOW in the drivers kick....LOW, down by the foot rest.  Under the carpet, find a LARGE harness  Theres a little plug attached with blue take. The plug is gray. BLACK/ white  and BLACK/ red  lock unlock..
Posted By: jaurora
Date Posted: March 06, 2005 at 11:31 AM
Thanks,
I will try it this weekend. I dident think of going under there but will give it a try.
Jeremy
