2005 Scion xB power locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51386
Printed Date: April 27, 2024 at 4:57 PM
Topic: 2005 Scion xB power locks
Posted By: leathur
Subject: 2005 Scion xB power locks
Date Posted: March 06, 2005 at 12:12 AM
Hello. I have installed a CrimeGuard 745i2 into my 2005 xB. This alarm used to be in my Integra, but i upgraded to a Viper 791. Anyway, the CrimeGuard is working fine on the xB except that i cannot get it to LOCK the doors when the alarm is armed. However, i was able to finally get it to UNLOCK when disarming.
I realize, on the Scions, the UNLOCK requires a double pulse (-) and the Crimeguard 745i2 only puts out a single unlock pulse. It has no option for a double pulse. (maybe the Crimeguard 745i4 has this option). After further research, i found out that i could tap into the UNLOCK wire (blue/red) on the passenger side kick panel instead, because it only requires a single pulse.
Does the brain need to send out a double pulse for it to LOCK? If so, then i guess im out of luck. I'm connecting to the LOCK wire (Blue/White) located in the drivers side kick panel, as suggested by the wiring guides i have seen. Any help would be appreciated. Thank you.
Posted By: another-kelly
Date Posted: March 06, 2005 at 1:11 AM
SCION / XB / 2005 / Remote Start12volts | wht/blue (40A), wht/red (15A) | + | ignition harness | Starter | black | + | ignition harness | Second Starter | N/A | | | Ignition | black | + | ignition harness | Second Ignition | BLACK / YELLOW | + | ignition harness | Third Ignition | N/A | | | Accessory | blue/red | + | ignition harness | Second Accessory | N/A | | | Keysense | yellow | - | ignition harness | Power Lock | blue/white | - | driver kick, 14 pin plug | Notes: Meter these wires while turning the key in the driver door key cylinder. | Power Unlock | yellow/black (double pulse) | - | driver kick, 14 pin plug | Notes: Meter these wires while turning the key in the driver door key cylinder.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug. | Lock Motor | blue/orange | 5wi | driver kick, 9 pin plug | Unlock Motor | YELLOW /GREEN | 5wi | driver kick, 9 pin plug | Parking Lights+ | green | + | headlight switch | Notes: Also found at the top of the fuse box in a 13 pin plug. | Parking Lights- | N/A | | | Hazards | GREEN/ orange | - | hazard switch | Turn Signal(L) | GREEN/ black | + | top of fuse box, 13 pin plug | Turn Signal(R) | GREEN/ YELLOW | + | top of fuse box, 13 pin plug | Reverse Light | RED / black | + | top of fuse box, 9 pin plug | Door Trigger | RED / white | - | top of fuse box, 9 pin plug | Dome Supervision | use door trigger wire | | | Trunk/Hatch Pin | common with door trigger wire | | | Hood Pin | N/A | | | Trunk/Hatch Release | N/A | | | Power Sliding Door | N/A | | | Factory Alarm Arm | N/A | | | Factory Alarm Disarm | N/A | | | Disarm No Unlock | N/A | | | Tachometer | black | ac | data link conn below fuse box, pin 9 | Wait to start | N/A | | | Brake Wire | GREEN/ red | + | brake pedal switch | Notes: Also found at the top of the fuse box in a 13 pin plug. | Parking Brake | black | - | parking brake switch | Horn Trigger | WHITE/ red | - | steering column | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Immobilizer Bypass Module: | Required: No | Type: N/A | Part #: N/A | Notes: N/A |
Date Posted: March 06, 2005 at 1:12 AM
thatsa whata i gotsa. hope ya can get to unlock
Posted By: leathur
Date Posted: March 06, 2005 at 1:29 AM
Thanks. That looks like the wiring guide i was using. I can get it to unlock, but i cannot get it to lock when i connect the lock wire from the brain to the blue/white wire on the 14 pin plug located in the drivers side kick panel
Date Posted: March 06, 2005 at 1:36 AM
you using a DMM? disconnect your lock wire from the blue/white and check it for it's neg. locl pulse when you are. did you also meter the blue/white with a DMM per the wiring info?
Posted By: leathur
Date Posted: March 06, 2005 at 8:10 PM
i was about to meter the blue/white wire and then i remembered there were 2 violet wires on the door lock harness that were grounded when i had the alarm in my integra. so i grounded those 2 violet wires and everything's fine now. Thanks for your help!
