2005 Ford Mustang Door Trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51638
Printed Date: April 28, 2024 at 5:14 PM
Topic: 2005 Ford Mustang Door Trigger
Posted By: sattsecurity
Subject: 2005 Ford Mustang Door Trigger
Date Posted: March 09, 2005 at 7:15 PM
I installed a black widow alarm on a ford mustang 2005 and used the dome supervision as a door trigger. When armed the alarm keeps chirpping as if a door was open. Sometimes the alarm would also go off. I tried looking for the BLACK/ Blue wire which is the dome light but cant seem to find it anywhere. I already checked in passenager kick where the SJB box is at and still nothing. I have gone so far as to taking about the door panels to find the wire but the only wire from the door switch is Yellow/Red.
Posted By: thepencil
Date Posted: March 09, 2005 at 9:44 PM
light GREEN/ black @SJB
YELLOW /GREEN @SJB
My wiring diagram show the following.
------------- Be careful whose advice you buy, but be patient with those who supply it.
Posted By: KarTuneMan
Date Posted: March 10, 2005 at 2:23 PM
The SJB is located in the pasenger kick. The pencils got it right on!!! -------------
Date Posted: March 15, 2005 at 2:05 PM
Thanks Dude.
Posted By: Teamrf
Date Posted: March 15, 2005 at 6:30 PM
Its in the harness running up the firewall.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Date Posted: April 04, 2005 at 12:34 AM
I used the light GREEN/ black. I found YELLOW /GREEN but it didn't do anything. There was actually two of those wires. Light GREEN/ black is at ground when the doors are shut. It drops the ground and goes to nothing when the doors are opened. I used a relay to throw a positive when the doors are opened. The problem I have now is that when the doors are closed, the relay is latched and charged. How much Juice will this draw on the battery and how long can a car sit with the relay latched before the battery goes dead? Any suggestions would greatly be appreciated.
Posted By: SOUND PRESSURE
Date Posted: April 04, 2005 at 2:52 AM
Just throwing something out there but is it possible to follow the door trigger wire and tap into it?
------------- Sound Pressure
Date Posted: April 04, 2005 at 10:48 AM
WiringInstructions.com and DEI's site directech.com both has it as black light blue(+) at SJB box. I've tried it. That wire is the dome supervision. It's not reliable, the alarm keeps going off because it thinks the doors are open. Light GREEN/ Black what 'thepencil' told me seemed to be the only wire that can be used, yet it poses the problem i posted above. How much amps does a relay draw and how long will the battery last if the relay is charged (doors closed) all the time? Ex: if the car is parked for a week without any activities.
Posted By: Rich06
Date Posted: May 15, 2005 at 8:59 AM
Has anyone successfully got the door pins to trigger the alarm properly. If so how. Having trouble on the dome light surv. wire tripping the alarm after 1/2 hour. The door pins are grnded when door is closed...I also don't to leave relays energized for long periods.Thx
Posted By: NowYaKnow
Date Posted: May 15, 2005 at 9:50 AM
Use the light GREEN/ YELLOW (-) wire coming down the passenger a-pillar. If that falses, wire a relay in as follows:
Pin 85: To light GREEN/ YELLOW
Pin 86: To 12volts constant
Pin 30: To ground
Pin 87: To negative door trigger on module
You could also run pin 30 to 12volts constant and pin 87 to your positive door trigger on the module if you prefer it.
Mike
Posted By: nava94
Date Posted: May 16, 2005 at 10:12 PM
nowyaknow is correct the vehicle has a module that shuts off and goes to sleep after 30minutes.that is what's causing the alarm to false.regarless if the car sits for a week or so the battery still drops voltage.
Posted By: jdiebolt
Date Posted: May 16, 2005 at 11:36 PM
Please forgive me if this is a stupid question... So, I have the 05 Mustang which is Grounded when the Door is closed and Open when the Door is Open. My Alarm has a negative input for door Open detection. So what I need to know is how do I wire a relay to Open when Grounded and Grounded when Open? My current setup is using the dome and I have the same issue as everybody else... About a half hour after setting the alarm, it goes off because it thinks a door was triggered.
