need alarm wiring for this vehicle thanks in advance.
DIRECTWIRE™ WIRING INFORMATION - DODGE / INTREPID / 2002 / Remote Start
12volts pink/black or red + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition dk. blue/white + ignition harness
Second Ignition GREEN/ red + ignition harness
Third Ignition
Accessory BLACK/ orange + ignition harness
Second Accessory BLACK/ white + ignition harness
Keysense
Power Lock WHITE/ green + back of fusebox
Notes: Locks are positive trigger through resistors. Use 2.7K (2700) ohms for lock and 620 ohms for unlock. MUST use relays.
Can also use Directed 457C or 456L interface modules.
Power Unlock same wire
Lock Motor orange BCM
Notes: BCM is located on the left side of dash with junction block.
Unlock Motor dk. blue BCM
Parking Lights+ do not use
Parking Lights- yellow headlight switch
Notes: Use a 110 ohm resistor to ground (-) for parking lights and a 220 ohm resistor to ground (-) will do both headlights and parking lights.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger tan and tan/red - BCM
Dome Supervision yellow - rear of fuse box, brown plug
Trunk/Hatch Pin tan/black - drivers kick panel
Hood Pin
Trunk/Hatch Release BLACK/ white + at release switch
Power Sliding Door
Factory Alarm Arm lt. GREEN/ orange + drivers kick panel
Notes: Arm is positive trigger thru a 1.87K ohm resistor, this will also lock the doors. Disarm is positive trigger thru a 680 ohm resistor, if use double pulse this will also unlock the doors. Must use relays.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer one of the coils
Notes: This vehicle has an ignition coil for each cylinder. For tach use a tan/stripe wire at any one of the coils.
Wait to start
Brake Wire WHITE/ tan + at brake switch
Parking Brake
Horn Trigger BLACK/ red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Be careful whose advice you buy, but be patient with those who supply it.
