2000 grand am security light staying on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52313
Printed Date: May 21, 2024 at 5:37 PM
Topic: 2000 grand am security light staying on
Posted By: tommy...
Subject: 2000 grand am security light staying on
Date Posted: March 21, 2005 at 7:13 PM
Hey guys i have a customer who will be returning b/c her security light stays on after the vehicle has been r/s'ed,and while driving ...any ideas? the car is a 2000 pontiac grand am
------------- M.E.C.P & First-Class
Posted By: auex
Date Posted: March 21, 2005 at 9:44 PM
There is a problem with the bypass or bypass wiring. You should try by checking the wiring out. You should also triple check the ground. If all the wiring checks out then replace the module and see if the problem still persists. I have had a ton of DEI 555Ls go bad.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: dare_ds69
Date Posted: March 22, 2005 at 6:14 PM
make sure you get the right wires for 555l sometimes is white or black or ORANGE / black
------------- how own your mind, control your life.
MECP certified. always use a DMM
Posted By: DENNY10700
Date Posted: March 24, 2005 at 6:43 AM
I have a 200 s10 with the same prob. Any info on your vehicle would be much appreciated. Thanx Denny
Posted By: mnviking28
Date Posted: March 24, 2005 at 3:41 PM
I have to agree. It almost has to be a passlock issue. If it is just a little off, it will still start, but will trip the security code. Use a good quality dmm and compare the voltage when started by the key as compared to started by r/s. Make sure they are the same.
------------- MNViking28
Posted By: Velocity Motors
Date Posted: March 24, 2005 at 7:43 PM
What bypass did you use ? I know in the past I have made the mistake of placing the jumper on some of the bypasskit.com modules in the wrong orientation and it worked, but the security light or passlock light was left on until the key was removed and restarted.
------------- Jeff
Posted By: tommy...
Date Posted: March 30, 2005 at 11:09 PM
hey thank you for all the responses.The customer should return in about a week...so you think the module is bad...hmmmmm.the first one i used didnt even work...thanks again and i will re-check the wiring,
