f150 R/S keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52391
Printed Date: May 15, 2024 at 5:50 PM
Topic: f150 R/S keyless entry
Posted By: comp123
Subject: f150 R/S keyless entry
Date Posted: March 22, 2005 at 7:10 PM
I installed a remote start in a 2002 Ford f150 PU. The only trouble is when the remote start is activated the factory transmitters for keyless entry no longer work. Any help on how I can get the factory remotes working again while the remote strart is engaged.
------------- chas
Posted By: daniel2002p
Date Posted: March 22, 2005 at 9:57 PM
Any factory system will not work as soon as the ignition is turned on. There may be smarter guys out here to give you that.
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: chris354
Date Posted: March 22, 2005 at 10:15 PM
You can go to the keyless entry module find the black and pink wire test to make sure its ignition Then you can either cut it into or build a relay to interupt it when the truck is remote started.If you are using a dei product there is a yellow wire that is on the main harness it will only put out ignition when the key is on. You can cut the black and pink wire intoand hook this yellow wire up to the keyless side.
Date Posted: March 23, 2005 at 7:16 AM
That sounds like a good idea, and as stated before make sure that you use the third ign output or status output from the alarm. One more thing, chris354 doesnt the factory keyless have a starter kill included??? Just a thought? I know mine did, but then again I do not have that truck.
1.8L VVT-i I-4
