2004 Hyundai Elantra remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52899
Printed Date: April 27, 2024 at 5:04 AM
Topic: 2004 Hyundai Elantra remote start
Posted By: SOUND PRESSURE
Subject: 2004 Hyundai Elantra remote start
Date Posted: March 31, 2005 at 1:18 AM
Hello,
Attempting to add a remote start to this vehicle. I need ask if this has some type of immobilizer or something like that. Also the door look type and if and relays are needed and diagram if so. The alarm that they have I believe is a phoenix digital pf152 not sure. Thanks!
------------- Sound Pressure
Posted By: dare_ds69
Date Posted: March 31, 2005 at 3:07 PM
12volts | red (x2)(common 40A) | + | ignition harness | Starter | white | + | ignition harness | Second Starter | N/A | | | Ignition | red | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | red | + | ignition harness | Second Accessory | yellow | + | ignition harness | Keysense | green | + | ign harn or ETACM, 16 pin plg, pin 2 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Power Lock | yellow | - | dr kick or ETACM, 20 pin plg, pin 20 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Power Unlock | yellow/orange | - | dr kick or ETACM, 20 pin plg, pin 14 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls.
To unlock the driver door only, use blue (-) at the relay to the right of the fuse box, or at the ETACM, 16 pin plug, pin 1. | Lock Motor | gray | 5wi | driver kick or door lock control mod | Notes: The door lock control module is in the center console, behind the A/C controls.
| Unlock Motor | yellow | 5wi | driver kick or relay R of fuse box | Parking Lights+ | GREEN/ orange (L), pink (R) | + | fuse box, blk 14 pin plg, pins 8, 14 | Parking Lights- | blue | - | switch or ETACM, 16 pin plug, pin 14 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Hazards | green (only w/fac. alarm) | - | ETACM, 12 pin plug, pin 8 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Turn Signal(L) | yellow/orange | + | turn signal switch | Turn Signal(R) | blue | + | turn signal switch | Reverse Light | brown | + | driver kick, 15 pin plug, pin 2 | Door Trigger | yellow | - | dr kick or ETACM, 20 pin plg, pin 18 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Dome Supervision | yellow | - | fusebox or ETACM, 20 pin plg, pin 11 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Trunk/Hatch Pin | green to GREEN/ black | - | dr kick or ETACM, 20 pin plg, pin 10 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Hood Pin | GREEN/ black | - | pin sw or ETACM, 12 pin plug, pin 7 | Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. | Trunk/Hatch Release | N/A | | | Power Sliding Door | N/A | | | Factory Alarm Arm | factory remote only | | | Factory Alarm Disarm | factory remote only | | | Disarm No Unlock | with ign, acc, and key sense | | | Tachometer | blue | ac | PCM, 81 pin plug, pin 66 or cluster | Notes: The PCM (Powertrain Control Module) is above the driver kick panel.
Can also go to any fuel injector and use the wire that is NOT white. | Wait to start | N/A | | | Brake Wire | white | + | brake pedal switch or driver kick | Parking Brake | blue | - | parking brake switch or driver kick | Horn Trigger | red | - | horn switch | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Immobilizer Bypass Module: Not Available |
------------- how own your mind, control your life.
MECP certified. always use a DMM
Date Posted: April 01, 2005 at 2:04 AM
Thanks Dare,
So this is a 5 wire setup for the door locks. As far as the remote start it has a keysense, how do we go about bypassing that unit?
Thanks,
Date Posted: April 01, 2005 at 6:02 PM
for power locks you don't need 5wires read again you need negative pulse and it doesn't have immobilizer
Date Posted: April 01, 2005 at 11:56 PM
Thanks for the info. The wiring info was a little confusing sorry, but thanks for the help.
Posted By: KarTuneMan
Date Posted: April 03, 2005 at 1:00 PM
If the vehicle came with factory keyless...the door locks are negative trigger, and they're a bitch to get to (behind the radio) if no factory keyless....you need to add an actuator to the drivers door (another bitch) I hope your car has factory keyless dude!!!! lots easier! -------------
Posted By: hurtado_roberto
Date Posted: May 01, 2005 at 10:53 AM
The dome supervision wire is actually white in my 04 elantra. It sais it's white at the bulldog security website to. https://www.bulldogsecurity.com/diagrams/diagrams.htm I'm not sure how to connect the parking light yet. This diagram is a bit confusing. Hopefully I'll figure it out soon. https://64.85.6.129/extrainfo/diagrams/15281_ELANTRA_DUAL%20PARKING%20LIGHT%20DIAGRAM.pdf Can anyone help me interpret this. The alarm output will trigger one light and the relay. You need a relay to isolate the lights from each other. How much current will this draw? Will it be more than the alarm can handle. Is it possible to switch the jumper on the viper 791xv to (-) and connect the negative wire or will this really mess up my car. (first install) ------------- Poly Dollies
Posted By: Velocity Motors
Date Posted: May 01, 2005 at 11:14 AM
Use the (-) trigger instead. It's easier and less hassles without the need for relays.
------------- Jeff
Date Posted: May 01, 2005 at 12:45 PM
I connected the domelight output of the alarm ETACM, 20 pin plg, pin 11 which was white but the light seams a bit dim when I disarm the alarm. Do I need to add a relay to this output. I did notice that wire 11 is affected by the delayed turnoff time. Should I choose a different wire?
