99 corvette remote start.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53177
Printed Date: May 20, 2024 at 1:25 AM
Topic: 99 corvette remote start.
Posted By: tcr03
Subject: 99 corvette remote start.
Date Posted: April 03, 2005 at 11:07 PM
i put a dei remote start on a 99 vette. i couldnt get it to remote start. it would send 12 volts through the starter wire but wouldnt crank the starter. need some help.
Posted By: Velocity Motors
Date Posted: April 03, 2005 at 11:31 PM
What bypass module did you use to bypass the PAsslock system ?
------------- Jeff
Posted By: tcr03
Date Posted: April 03, 2005 at 11:36 PM
no passlock. it has vats.
Date Posted: April 03, 2005 at 11:48 PM
What wire did you use for the starter ? There's also a YELLOW/BLACK wire at the BCM. ------------- Jeff
Posted By: tcr03
Date Posted: April 03, 2005 at 11:50 PM
yeh i know about that wire, but you cant use it for remote start. so i used the yellow thick gauge wire at the ignition harness
Posted By: tcr03
Date Posted: April 03, 2005 at 11:51 PM
another thing. do you know of a good spot to get the tach, besides at the pcm.
Posted By: OhioMike1101
Date Posted: April 04, 2005 at 2:11 AM
Did a 2000 Vette not long ago and the PCM sucked. Took off passenger wheel and it was behind the wheel well. Very hard to get access to the wires. Ended up just using voltage sense and it works great on voltage sense.
Date Posted: April 04, 2005 at 6:21 AM
You can use an injector wire as well. Use any wire opposite from pink. Also you didn't mention if this was a manual or auto transmission.
------------- Jeff
Posted By: tcr03
Date Posted: April 04, 2005 at 8:16 AM
its an auto of course. we dont put them on manuals at work.
Posted By: tcr03
Date Posted: April 05, 2005 at 12:28 PM
i found the problem. the brown 2nd acc wire on the car needs to be hooked up as a acc wire and not an ignition wire. it must not have 12volts while cranking.
