2004 dodge neon alarm/remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53315
Printed Date: March 29, 2024 at 5:34 AM
Topic: 2004 dodge neon alarm/remote start wiring
Posted By: hndcufd
Subject: 2004 dodge neon alarm/remote start wiring
Date Posted: April 05, 2005 at 2:59 PM
please help I need a wiring diagram for a 2004 dodge neon, trying to hook up a alarm with remote start..
sos
eckenrode
Posted By: mo12v
Date Posted: April 05, 2005 at 9:35 PM
Alarm
Constant 12 voltsPINK/BLACK & REDIGNITION SWITCH HARNESS
Ignition 12 voltsDARK BLUE (14 gauge)IGNITION SWITCH HARNESS
StarterYELLOW (14 gauge)IGNITION SWITCH HARNESS
Dome LightYELLOW (-)DRIVER'S KICK PANEL
Trunk Pin SwitchTAN/BLACK (-)AT LIGHT IN TRUNK
Parking LampBLACK / YELLOW (+)STEERING COLUMN OR RKE*
Power LockLT.GREENDRIVER KICK PANEL **
Power UnlockSINGLE WIRE SYSTEMSAME AS LOCK **
* RKE Module Located At Access Panel On Top Of Dash **LT GREEN Door Lock Wire Must Recieve A (-) Negative Ground Pulse Throu A 1K Ohm Resister To Lock And A (-) Negative Ground Pulse Through A 250 Ohm Resister To Unlock.
Single Wire Resistor Door Lock Circuit
Accessories
Window UpD\ LIGHT BLUE P\ BROWN / WHITE @ MAIN SWITCH
Window DownF/ WHITE/ LT BLU F/ VIOLET/WHITE REVERSAL AT GROUND
Ign Key WarnL BLUE (-)STEERING COLUMN HARNESS
Trunk ReleaseBROWN / LT BLUE (-)TRUNK RELEASE SWITCH OR RKE *
OEM HornBLACK/ RED (-)STEERING COLUMN HARNESS OR RKE *
HeadlightsVIOLET/WHITESTEERING COLUMN HARNESS
OEM Alarm ArmLT GREEN/ ORANGEDRIVER KICK PANEL **
OEM Alarm DisarmSINGLE WIRE SYSTEMSAME AS ARM **
 Reversal Rest At Ground Window Circuit
  Ground Pulse Trunk Release Circuit
* RKE Located At Access Panel At Top Of Dash ** LT GREEN/ ORANGE Wire Must Receive A Ground Pulse Through What Has Been Reported As A 2.7K Ohm Resistor To ARM/LOCK And A Ground Pulse Through What Has Been Reported As A 7.5K Ohm Resistor TO DISARM, Double Pulse Will UNLOCK
Remote Start
Tach SignalBLACK/ GREYAT COIL
Ignition #2BLACK/ ORANGEIGNITION SWITCH HARNESS
Ignition #3
AccessoryBLACK/ ORANGEIGNITION SWITCH HARNESS
Neutral SafetyYELLOWIGNITION SWITCH HARNESS
Brake LightWHITE/ TAN (+)SWITCH AT TOP OF BRAKE PEDAL
Reverse LightVIOLET/BLACK (+)6 PIN CONN POS 1 BEHIND DRIVER'S KICK
Rear Window DefrostBLACK/ WHITE (+)5 PIN CONN BACK OF REAR DEFOG SWITCH*
 Immobilizer Bypass Circuit
* Must Use Relay- High Current Output To Defrost Grid RKE ACC +12v- DK BLUE/WHITE At RKE. RKE Located At Access Panel, Top Of Dash. Programming An Additional Transponder Key Requires 2 Valid Sentry Keys.Key 1 On 5-7 secs.Off,Replace W/Key 2-On,After Tone,Replace W/New Key-On Till Tone.
Programming OEM Transmitters:Requires One Existing Transmitter Programmed. Turn Ignition Switch ON ,After Chiming Stops, Hold UNLOCK Button 5-7 Secs.Of Orininal Transmitter; Press PANIC Button- Should Get 1 Chime Indicating Program Mode. Press Any Button On That Remote-Chime, Press Any Button On Next Remote- Chime.You Can Program Up To 4 Remotes. Key OFF * Each Remote Must Be Programmed Including Any Existing Remotes.* OEM Hood Pin Wire Is BROWN / TAN At Hood Pin Switch Or RKE Model, Pin #23 Of 24 Pin Connector. (Export Models)
MO
Posted By: dare_ds69
Date Posted: April 06, 2005 at 6:10 AM
12volts pink/black (40A), red (30A)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition dk. blue  +  ignition harness
Second Ignition RED / wht (with Autostick only)  +  ignition harness
Third Ignition N/A
Accessory BLACK/ orange  +  ignition harness
Second Accessory BLACK/ white  +  ignition harness
Keysense lt. blue  -  ignition harness
Power Lock lt. green  -  driver kick, door harness
Notes: Lock is negative trigger thru a 1K (1000) ohm resistor. Unlock is negative trigger thru a 250 ohm resistor. MUST use relays.
If the vehicle has factory alarm, arm/lock is negative trigger thru a 2.7K (2700) ohm resistor, and disarm/unlock is negative trigger thru a 7.5K (7500) ohm resistor, use double pulse for unlock.
Also found at the Remote Keyless Entry Module in the top center of the dash. Remove the dash top to access.
Can also use Directed 457C or 456L interface modules.
Power Unlock same as power lock wire
Lock Motor ORANGE / black  5wi driver kick, door harness
Notes: Also found at the Remote Keyless Entry Module in the top center of the dash. Remove the dash top to access.
Unlock Motor pink/black  5wi driver kick, door harness
Parking Lights+ BLACK / YELLOW  +  headlight switch
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt. green (F), dk. grn/red (R) +  turn signal switch
Turn Signal(R) tan (F), BROWN / red (R)  +  turn signal switch
Reverse Light PURPLE / black  +  driver kick, harness to rear
Door Trigger tan/blk (D), lt. blue/org (P)  -  dr kick, door harn and harn to rear
Notes: Use both wires and diode isolate each.
Dome Supervision yellow  -  driver kick, harness to rear
Trunk/Hatch Pin tan/black  -  trunk pin switch or light in trunk
Hood Pin BROWN / tan (export model only)  -  hood pin switch under hood
Trunk/Hatch Release BROWN / lt. blue  -  release switch in glovebox
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT dk. GREEN/ orange  ac  ignition coil or any fuel injector
Wait to start N/A
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake WHITE/ black  -  parking brake switch
Horn Trigger BLACK/ red  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
posted_image
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
how own your mind, control your life.
MECP certified. always use a DMM
