CA-645, Door Locks and Sensitivity?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53943
Printed Date: May 17, 2024 at 6:05 PM
Topic: CA-645, Door Locks and Sensitivity?
Posted By: Buckshot06
Subject: CA-645, Door Locks and Sensitivity?
Date Posted: April 14, 2005 at 10:21 PM
Code Alarm CA-645, I need to reverse the polarity of the locks somehow, and turn the sensitivity on the alarm up alot, it doesn't do sh*t. I would take it to the dealer, circuit city, but I absolutely hate them period.
I hit arm, and it UNLOCKS the doors, whne it's sapposed to LOCK them, thats what I mean by polarity, and the sensitivity thing, you could role my car down a cliff and the alarm wouldn't go off.
Thanks, I'm new, I searched, and didn't see anything..!
Buck
Jason
Posted By: infoaudio01
Date Posted: April 14, 2005 at 10:48 PM
If I remember correctly, the CA-645 has an on-board shock sensor which means that the "brain" needs to be 1- Zip tied to the fattest harness under the dash, or 2- Mounted to the firewall securely. As far as how to switch polarity on the alarm is simple, but it all depends on what type of door locks you have. Keep in mind that code alarm switches polarity with their door lock wires by reversing them. If you connected Green to door lock wire and Blue to unlock, then connect Blue to lock and Green to unlock. Hate is a strong word.
Date Posted: April 15, 2005 at 9:12 AM
Anyone have a wiring diagram for the CA-645? So in esence what your telling me is that the brain is the only shock senser? Thats sweet. Not.
