I wont to purchase the viper alarm 791xv for hyundai santa fe 2001 and i wont to do the installation my self.The installation whith the alarm here in montreal cost 650$ plus tax.Please somebody to help me!Thank you.
I think i can get it for 189$ us.if somebody can help me with the installation i really apreciate.Thank you.
i have the wiring diagram for hyundai santa fe.do i need the bitwriter to set up the alarm?
I am a bit confused which one is better hornet 554 or viper791xv 2-way.Inow that both of them are made by dei.one of this alarms i wont to install on my 2001 hyundai santa fe.The hornet comes with 2 remotes.I never installed an alarm system.Can somebody help me please!THANKS.
They are very similar. It really is an opinion as to which one is better. If you know electrical systems you should be fine. If not, you may want to get with someone that can help you if you are not willing to pay someone to do it for you.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Thank you for you're advise.I have a bad experience whith garaje and i am very pozitiv that i can do it my self.Can you help me?
i wont to know if somebody knows if there are files with pictures that shows me how to install a viper-791 xv 2-wayfor hyunday santa fee.i hope that you can help me thanks.
Yes there are. If you are looking for a wiring diagram and picture, we maybe able to provide you with one. What year is your car? By the way, write only in lower case letter. Capitalizing your sentence means you are yell. So far, we can hear you very well.
Be careful whose advice you buy, but be patient with those who supply it.
My car is a 2001 hyundai santa fe 2.7l.Thank you very much for you're help.Sorry for the capital letter.
Viper 791XV
DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / SANTA FE / 2001 / Remote Start
12volts red and blue + ignition harness
Starter lt. GREEN/ black + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition pink + ignition harness
Third Ignition N/A
Accessory blue + ignition harness
Second Accessory N/A
Keysense brown + ignition harness
Power Lock yellow - driver kick, white 22 pin plug
Power Unlock WHITE/ black - driver kick, white 22 pin plug
Lock Motor gray 5wi driver kick, white 22 pin plug
Unlock Motor white 5wi driver kick, white 22 pin plug
Parking Lights+ GREEN/ orange + fuse box, 15 pin plug
Parking Lights- lt. blue/blue - headlight switch
Hazards green (only w/fac. alarm) - ETACS, 12 pin plug
Notes: The ETACS module is attached to the back of the fusebox on the bottom.
Turn Signal(L) pink + steering column
Turn Signal(R) gray + steering column
Reverse Light RED / black + fuse box, top right plug
Door Trigger yellow - fuse box, 8 pin plug
Dome Supervision use door trigger
Trunk/Hatch Pin BLACK/ orange - fuse box, 15 pin plug
Hood Pin pink - ETACS, 12 pin plug
The hood pin is also green at the switch under the hood.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock disarms with remote start
Tachometer WHITE/ black or blue ac ECM
Notes: The ECM (Engine Control Module) is under the center console to the right of the gas pedal. On the 2.4L with A/T it is in the 26 pin plug, the 2.4L with M/T it is in the 12 pin plug, and the 2.7L it is in the 40 pin plug.
Wait to start N/A
Brake Wire GREEN/ black + brake pedal switch
Parking Brake GREEN/ black - parking brake switch
Horn Trigger brown - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Is anybody that have pictures of installation for a 2001 hyundai santa fe .
