1996 Mercury Villager
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55480
Printed Date: May 16, 2024 at 3:59 PM
Topic: 1996 Mercury Villager
Posted By: swfx
Subject: 1996 Mercury Villager
Date Posted: May 10, 2005 at 2:33 PM
Can someone please help me with the door trigger and rear hatch trigger on this vehicle?  I know the wire colors and I have probed almost every single wire matching the description with no success.  Where are these wires on this vehicle?  Please don't say driver's kick panel because that is where I have been checking.  Please be as specific as possible if you have done one of these vans before.  Thank you.
Posted By: swfx
Date Posted: May 10, 2005 at 3:23 PM
Yes I did search for this car.  The other post is a totally seperate issue which I'm not getting a response on.  Thanks for this response though.
Posted By: swfx
Date Posted: May 10, 2005 at 3:46 PM
I specified that I knew the color and the location.  Have you installed an alarm on this vehicle?  If you have then you know that there are about 10 RED / White wires in the driver kick panel.  I have metered every single one of them and none of them react to the door trigger.  That is why I am asking for help.  The same thing with the Lt BROWN / White in the driver's kick panel for the rear hatch trigger.
Anyone who has installed an alarm on this vehicle...please help me.
Posted By: mo12v
Date Posted: May 10, 2005 at 4:01 PM
How about this:
Dome LightWHITE (-)AT "SMART ENTRY CONTROL TIMER" *
Trunk Pin SwitchBROWN / WHITE (-)AT "SMART ENTRY CONTROL TIMER" *
Parking LampORANGE / BLACK (-)AT HEADLIGHT SWITCH **
* "Smart Entry Control Timer" Located Behind Driver Dash To Right Of Steering Column. ** ORANGE / BLACK (-) At Headlight Switch Is Output From Headlight Switch To Taillight Relay At Interior Fuse Panel. Output From Relay To Park Lights Is PINK/BLUE (+) Or PINK/WHITE (+) At Interior Fuse Panel.
MO
Posted By: swfx
Date Posted: May 10, 2005 at 5:25 PM
Thanks Mo.  I wish you were in the same timezone as me because you are always so helpful.  So with (+)Park Light output from alarm, I should connect to Pink Blue right?  That is where I have it hooked up now.  Thanks again for the alternative spots.  The RED / White wires for door trigger all sucked!
Posted By: swfx
Date Posted: May 10, 2005 at 9:37 PM
Problem solved.  Alarm installed and working great!  Mo is the best!  Everyone should try and be as helpful as Mo.
