Compustar causing false alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55514
Printed Date: May 04, 2024 at 6:53 PM
Topic: Compustar causing false alarm
Posted By: ekdude
Subject: Compustar causing false alarm
Date Posted: May 10, 2005 at 11:38 PM
Compustar CM300 2WFM-AS
Car: Mazda 626 Cronos 1997
Has aftermarket door locks
_______________________
after about a month the alarm goes off on it's own and I have know idea where to begin... I decided to turn down the shock sensor.. and remounted it... For some reason the shock sensor doesn't seem to work, but the light on the shock sensor lights up showing that it works... what seems to be problem?
Also where is the best place to start diagnosing when I have a false alarm...?
Any suggestions would be greatly appreciated...
Posted By: Velocity Motors
Date Posted: May 11, 2005 at 12:11 AM
The remote control should tell you diagnostics of what is triggering the alarm system to be set off. YOu can turn on and off your shock sensor from the remote control. Did you turn off the shock sensor ? Did you solder all your connections or not ?
Posted By: thepencil
Date Posted: May 11, 2005 at 8:40 AM
An added note to your diagnostics.
Check your hood pin first and make sure that's working properly. Completely remove your shock sensor and see if you are still getting false alarm.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: Ballerinstaller
Date Posted: May 18, 2005 at 5:57 PM
I have installed a 2wss-as in my 2000 impala ls and WOW it was falsing after a month too.  My remote showed no zones tripped too.  I figured that the system may be erroring from the two programmable inputs as they will not show a indicator on the remote.  So I placed a 10K ohm resistor to ground on each input and then used a large ferrite choke  ring core to wrap all of my wires through.  No more problems.
Also my pager alert  (the thing that you knock on the window to trigger) would pick up birds chirping and any loud noises caused erroneous  pages being sent to my remote.  I cut the white wire in the harness going the the pager alerter and no more pages!  Instead of knocking on my window to page me, the person has to open my gas tank fill door to trigger the pager sensor through a magnetic reed switch network bought from RadioShack.
If your hood pin switch is at fault, a little indicator will light up in the driver side window on the remote.
Pioneer Avic-N1
Clarion 300 watt 4 channel amp
PPI PC21400 1400 watt amp
2x JL 12 inch w7's
Polk EX series in factory locations
2000 Impala LS
Baller Installer - Pete D.
