PT Cruiser remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55670
Printed Date: June 09, 2024 at 3:55 PM
Topic: PT Cruiser remote start
Posted By: golfnut64
Subject: PT Cruiser remote start
Date Posted: May 13, 2005 at 2:01 PM
Hi all I am trying to put a remote start in this 2002 PT with no luck getting a transponder bypass to work have tryed two different remote starters & several different bypass units . Does anyone know if it is possible to bypass this car or does the key have to be turned to keep it running , Please help Thanks
------------- Lloyd
Posted By: mo12v
Date Posted: May 13, 2005 at 10:11 PM
OMEGA makes a Transponder ByPass # IB-PKU-CH No Key Required OR # DB-CHDL--3PK....Transponder With Door Locks OMEGA also has a NEW one but I don't have that with me............. They work good for me
------------- MO
Date Posted: May 14, 2005 at 6:48 AM
Thanks but i now have the transponder out of a programed key taped on the ignition ring but it still will not start by remote & the only key that will start it is the one with out the chip, this tells me that the bypass is working , am i missing another ignition wire or does the key have to be turned to start ????? Thanks
------------- Lloyd
Date Posted: May 14, 2005 at 6:49 PM
Allright i found it tryed a fourth remote & that worked Thanks for the help
------------- Lloyd
