G35 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56130
Printed Date: April 27, 2024 at 8:54 PM
Topic: G35 remote start
Posted By: rac0000
Subject: G35 remote start
Date Posted: May 20, 2005 at 5:19 PM
I have a 2005 infiniti g35x on order and want to install a remote start.You guys helped me out big time on a remote start for my 2003 accord. I need to know what i'll need to do the job right. (modules and bypass kits?). Also a wiring diagram and wire location would be very helpful.Also,if anyone knows of any snags i may run into in the installation. Thanks ------------- rac0000
Posted By: Pearl96Max
Date Posted: May 20, 2005 at 10:51 PM
Congrats on your purchase. I just picked one up lastweek as as well.
All youll need is a 556U Immobilizer Bypass.
Heres the tech sheet:
DIRECTWIRE™ WIRING INFORMATION - INFINITI / G35 SEDAN / 2005 / Remote Start
[PRINT THIS PAGE]
12volts WHITE/ blue (40A) + ignition harness
Starter WHITE/ red + ignition harness
Second Starter WHITE/ green + ignition harness
Ignition BLACK/ red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory WHITE/ black + ignition harness
Second Accessory N/A
Keysense BLACK/ pink + ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is in the driver kick panel.
Power Lock RED / white - driver door module in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock blue/white (double pulse) - driver door module in door
Lock Motor purple 5wi BCM, pin 50
Unlock Motor yellow 5wi BCM, pin 44
Parking Lights+ RED / blue + driver kick, harness to rear
Parking Lights- N/A
Hazards GREEN/ red - switch or BCM, pin 29
Turn Signal(L) GREEN / WHITE + BCM, pin 45
Turn Signal(R) PURPLE / white + BCM, pin 46
Reverse Light red or orange + driver kick, harness to rear
Door Trigger white (D), pink (P)(x3) - BCM, pins 62, 12, 63 and 13
Notes: Use all four wires and diode isolate each.
Dome Supervision PURPLE / red - BCM, pin 48
The step lamps are yellow/purple (-) at the BCM, pin 47.
Trunk/Hatch Pin RED / white - BCM, pin 57
Hood Pin lt. GREEN/ black - hood pin switch under hood
Trunk/Hatch Release pink or blue - BCM, pin 30
The trunk release motor wire is GREEN / WHITE (+) at the BCM, pin 68.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT WHITE/ blue, red or black ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire pink/blue + brake pedal switch
Parking Brake RED / white or PURPLE / red - parking brake switch
Horn Trigger GREEN/ black - horn switch
Memory Seat 1 blue/green - memory seat switch on seat
Memory Seat 2 blue/black - memory seat switch on seat
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes: Standard on all models.
Date Posted: May 20, 2005 at 10:52 PM
From what Ive seen so far not all the wires are 100% accurate for the '05 models. Please test and confirm all colors prior to using.
Good luck
