2002 Toyota Sequoia Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5616
Printed Date: May 05, 2024 at 11:52 AM
Topic: 2002 Toyota Sequoia Remote Start
Posted By: mobileinstallat
Subject: 2002 Toyota Sequoia Remote Start
Date Posted: November 18, 2002 at 8:08 PM
plain stand alone rem starter going in, cust keeping factory keyless entry.
I already explained  about toyota door locks dont work wile engine is running, he has no prob with it. I know it has a transponder.
last one I did I sortof remember the parking lights being a pain- it was last season-didnt take notes. I have a wire chart for it, just looking to see if anyone else has one I can compare mine to- or any heads ups?
thanks in advance men.
Posted By: Velocity Motors
Date Posted: November 19, 2002 at 1:16 AM
Here are three different sources that I have for the 2002 Sequoia:
|              12V|wht/blue & wht/red  |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|  SECOND IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|pink                |+  |ignition harness            |
|       POWER LOCK|see direct fax      |   |                            |
|     POWER UNLOCK|document #1070      |   |                            |
|       LOCK MOTOR|blue/red            |   |blk plug, pin 1 @ BECU *4   |
|     UNLOCK MOTOR|RED / black           |   |blk plug, pin 14 @ BECU *4  |
|    DISARM DEFEAT|blue/black          |   |blk plug, pin 2 @ BECU *4   |
| PARKING LIGHTS +|green               |   |back of fusebox, 12 pin plug|
| PARKING LIGHTS -|green               |   |headlight switch            |
|       HEADLIGHTS|yellow/red          |-  |headlight switch            |
|     DOOR TRIGGER|*1                  |-  |*1                          |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|red                 |-  |in back door at ECU         |
|         HOOD PIN|blue/white          |-  |DKP, 26 pin plug in pin 4   |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|YELLOW /GREEN *3     |-  |ignition harness            |
|       TACHOMETER|YELLOW /GREEN        |   |ECM, 28 pin plug in pin 4 *2|
|      SPEED SENSE|GREEN/ orange        |   |ECM, 28 pin plug in pin 5 *2|
|       BRAKE WIRE|GREEN/ YELLOW        |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK / YELLOW        |-  |steering column             |
|           WIPERS|blu/blk(L),blu/red(H|+  |steering column             |
|  LF WINDOW UP/DN|red - green         |A  |LF window switch            |
|  RF WINDOW UP/DN|red - green         |A  |RF window switch            |
|  LR WINDOW UP/DN|red - green         |A  |LR window switch            |
|  RR WINDOW UP/DN|red - green *5      |A  |RR window switch            |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|blue / YELLOW         |+  |radio                       |
|     RADIO GROUND|brown               |-  |radio                       |
|     RADIO SWITCH|gray                |+  |radio                       |
| RADIO ILLUMINATE|green               |+  |radio                       |
|    POWER ANTENNA|WHITE/ blue          |+  |radio                       |
|       LF SPEAKER|pink - purple       |   |radio                       |
|       RF SPEAKER|lt. green - blue    |   |radio                       |
|       LR SPEAKER|black - yellow      |   |radio                       |
|       RR SPEAKER|red - white         |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.   *1 The two driver side door trigger wires are in a 14 pin plug in the driver kick panel. The driver door trigger is gray/red in pin 14, the left rear door is RED / white in pin 13. The two passenger side door trigger wires are in a 14 pin plug in the passenger kick panel. The front passenger door is lt. GREEN/ black in pin 14, and the right rear door is RED / white in pin 5. Use all four and diode isolate each.  *2 The ECM is behind the glove box.  *3 This is the ignition key sense wire. There are 2 YELLOW /GREEN wires in the ignition harness. The correct one is in a 2 pin plug. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.  *4 The BECU (Body ECU) is above the driver kick panel.  *5 To interface with the tailgate window, must runs wires into the tailgate. The up motor wires is pink and the down motor wire is white.
Toyota
Sequoia
2001-2002
Remote Starter  Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Start:
Yellow
BLACK/ WHITE
IGNITION SWITCH HARNESS *
Ignition  #1:
Blue
BLACK/ RED
Ignition #2:
Green
BLACK / YELLOW
Ignition  #3:
Wht/Blk
N/A
Accessory:
White
PINK
Brake  Light:
Orange
GREEN / WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
Green
YELLOW /GREEN
AT ECM PIN B4 **
Parking Lights:
Yellow
GREEN (+)
AT JUNCTION BLOCK ON PASSENGER SIDE AT ECM
Headlights:
Yellow
OEM Alarm  Disarm:
Brn/Wht
RED / YELLOW (-)
INSIDE OF DRIVER'S DOOR
OEM Alarm  Arm:
n/a
Diesel  Glow Plug:
RED / Black
Clutch  Bypass Wire:
n/a
Notes:
 * This vehicle is equipped with a transponder immobilizer system. ** ECM is located behind the glove box on passenger side of the vehicle.
Toyota
Sequoia
2001-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Constant  +12 Volts:
Red
WHITE/ BLUE
Starter  Kill:
Vlt or Wht
BLACK/ WHITE
Ignition  +12 Volts:
Orange
BLACK/ RED
Dome  Lights/Superv:
Brown
WHITE
AT BCM PIN B8***
OEM Horn:
Blue
WHITE/ RED (-)
DRIVER'S KICK PANEL
Power  Lock:
Wht/Red
SEE NOTE ****
Power  Unlock:
Yel/Red
SEE NOTE ****
Trunk  Release:
Grn/Wht
Alarm  Input Wire:
R/W or Gy/Bk
WHITE
AT BCM PIN B8***
Notes:
*** The BCM is located high on the drive's side underneath the dash. Test for correct wire. ****  Modern Toyota Door Locks.
WIRE COLOR LOCATION
12 VOLTS CONSTANT WHT/BLU IGNITION SWITCH HARNESS
IGNITION 1 BLK/RED IGNITION SWITCH HARNESS
IGNITION 2 BLK/YEL IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1 PNK IGNITION SWITCH HARNESS
STARTER BLK/WHT DOTS STANDARD IGN HARNESS
PARKING LIGHTS GRN (+) AT JUNCT BLOCK ON PASS SIDE AT ECM
DOMELIGHT WHT AT BCM AT DRIVER'S SIDE UNDER DASH
PWR DOOR LOCK
PWR DOOR UNLOCK
TACH SENSOR YEL/GRN AT ECM
BRAKE GRN/WHT (+) AT BRAKE SWITCH
HORN WHT/RED DRIVER'S KICK PANEL
FACTORY DISARM RED / YEL IN DRIVER'S DOOR
FACTORY ANTI-THEFT TYPE TRANSPONDER
Posted By: Chris Luongo
Date Posted: November 19, 2002 at 5:08 PM
The pink accessory wire is not needed for remote start; the climate controls are powered by the BLACK / YELLOW second ignition wire.
Positive parking lights, as well as brake lights, are easily available in a plug in the driver's kick panel.
Hoodpin:  There are two 26-pin plugs that are VERY far forward and high up in the driver's kick.  The hoodpin is in the lower (gray) of these two plugs.  It shows a partial ground even with the hood closed----cut it in half, and attach two diodes to the "hood" side of the wire.  One diode goes to the other side of the blue/white you just cut; the second diode goes into your remote start.  (Only models with a factory alarm have a hoodswitch.)
Tach:  Forget about pulling down the glove box and going to the ECM.  Above the gas pedal is a cluster of maybe ten plugs--some gray, some black, and some white.  There are several YELLOW /GREENs in there; a few of those wires are tach.  You can also get it at the instrument cluster---either by removing the cluster, or reaching way, way up above the gas pedal, to the back of the cluster, and attaching a T-tap (with your bare fingers---no tools will fit).  Also, I'm not finding the tach above the gas pedal on the 2003s.
Factory alarm disarm:  Just like the DEI sheet says---ground the key sense wire during remote start.
Transponder bypass:  Toyotas are a little fussy about how you place the coil around the key cylinder.  You'll want to tape it to the very front edge, against the flat area where it lights up.  When you install the dash back on, it'll hold the coil there even better.
How to test if the car has a factory alarm:  Close the tailgate and hood.  Then do one of these three things:  1.  Open a door, press Lock on the door, and close it.  2.  Press Lock on the factory remote.  3.  Close all the doors, and then lock them using the key.  ------ The security light in the instrument cluster should come on steady for thirty seconds, and then begin to flash slowly--the system is now armed.  If the security light NEVER comes on steady, but just flashes slowly all the time, you do not have an alarm---the light only serves to warn about the transponder key.
