Clicking Sound in Prestige APS996A Brain
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56286
Printed Date: May 13, 2024 at 5:27 PM
Topic: Clicking Sound in Prestige APS996A Brain
Posted By: spooken
Subject: Clicking Sound in Prestige APS996A Brain
Date Posted: May 23, 2005 at 12:28 PM
As the subject says. This is what I did:
The alarm installer didn't do a clean installation, so cable was a little messy and pretty much visible when I crouch trying to pop up the hood. It made my hands a little itchy whenever . So one day I decided to tidy up all the cables and have the brain unit secured (it was left overhanging secured only with cable tie). So I disconnected all the cables from the brain unit and finally got a good place to secure the unit. However when I tried testing it, it has this clicking sound in the brain unit and the remote doesn't respond anymore to the system.
The question I want to ask, is it possible that I somewhat short circuit the brain unit? What's the usual step of installing the whole system, e.g. which cables to plug in first or what kind of steps I've to do before I plug the cables into the brain? Any help is greatly appreciated. Thanks.
Posted By: daze
Date Posted: May 23, 2005 at 12:49 PM
is it a very rapid clicking sound or is it a little bit slower patern ? do the parking lights flash with the sound ?
Posted By: cleanlude
Date Posted: May 23, 2005 at 7:20 PM
Are clicking sounds bad, because my Autopage alarm i just installed today clicks on every command and everytime the parking lights flash or whatever. This is not normal?
Posted By: daze
Date Posted: May 23, 2005 at 8:43 PM
with most alarms... it is normal. It is the relays (switches) making and breaking contact
Posted By: daniel2002p
Date Posted: May 24, 2005 at 7:34 AM
sounds like that you need a new ground, try finding the black wire and reground it to a new ground and this should solve the clocking sound.
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
