2005 f150, viper 791
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56313
Printed Date: May 13, 2024 at 11:36 PM
Topic: 2005 f150, viper 791
Posted By: sikassscivic
Subject: 2005 f150, viper 791
Date Posted: May 07, 2005 at 9:26 PM
same as the older ones,ive done a 2003,i just bought a 2005,so do i use the same kind? anyone have any tips and maybe a diagram for me:D
Posted By: Velocity Motors
Date Posted: May 08, 2005 at 11:21 AM
The 2005 uses a new form of PATS and you will need a different system than the 2003. I use the PKF3 that directly hooks into the PATS wires and doesn't require you to loose a key in the installation & have had 0 problems with any of the customer's vehicles that it was installed into.
------------- Jeff
Date Posted: May 08, 2005 at 7:48 PM
i bought a pkm1 from you for a mazda maita,i could never get it to work,i tried for hours,i called you,still never got it to work.
Date Posted: May 22, 2005 at 9:18 PM
ok,i bought a viper 791 and the pkf-3 for my 2005 f150.couple questions. 1)the sheet that came with the pkf-3 does not have a little check mark next the 2005 f150,but does have a check mark next to the 2004,so before i even begin,is it going to work on my 2005?? 2)it says i need the tx and rx of my ecu,where are these and does anyone have the color and locations i can grab them at?
Posted By: JiggaFan
Date Posted: May 23, 2005 at 7:27 AM
the tech sheet shows what the tx/rx/gd/ign wires SHOULD be depending on what your plug at the transponder ring on the key cylinder looks like...at least i know that's how the PKF and PKF2 work on '00 Expedition and '03 Focus. BTW, I've yet to get the PKF or PKF2 to program for the Expedition and Focus I just mentioned. Not sure if it's user error or bypass module incompatibility, but I've had to use a spare key in a universal bypass on both those vehicles.
Date Posted: May 23, 2005 at 6:32 PM
oh,so if i had a "type a" plug i would just wire it up to those same wires that it shows?do i just splice into them,or do i actually cut any othe wires?there really is no installation instructions at all.just a chart that shows the plugs.
Date Posted: May 23, 2005 at 7:18 PM
sheets keep refering to the BCM,located on the back driver cabin wall.does this mean im going to need to take out my back seat to get to it?i have a supercrew.also,what bypass did you use?
Posted By: KarTuneMan
Date Posted: May 23, 2005 at 7:38 PM
what wires are you trying to "locate"
Posted By: mxxmikexx
Date Posted: May 23, 2005 at 8:21 PM
just call and talk to their tech guys, they are very helpful over there 1-888-745-2233
------------- Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: moshpitmickey
Date Posted: May 23, 2005 at 8:36 PM
You should be able to get to the wires without removing the seat . The bypass for remote start is 556S, 555U, or 556U. These are DEI part numbers.
------------- moshpitmickey
Date Posted: May 23, 2005 at 8:39 PM
Sorry, left this out. The bypasses are only needed for the light duty. Super Duty does not need a bypass. I'm not sure if a supercrew is considered heavy duty or not.
Date Posted: May 23, 2005 at 8:40 PM
if any one has better wiring diagrams,id love to see them,the only one i found kinda sucks.dosnt show anything for the dome light supervision. looks like the bcm is where all my door triggers are at. with a 791 viper,will i need to hook up the tach on my f 150?
Date Posted: May 23, 2005 at 8:41 PM
im pretty sure the f150 would be light duty,and 250's and up are heavy.
Posted By: JWorm
Date Posted: May 23, 2005 at 8:54 PM
F150's are light duty. The F250 comes in light and super duty. At least it did up until the new design. The F350 and higher is always a superduty.
Date Posted: May 23, 2005 at 10:09 PM
the pkf-3 says it needs a ground when running,can i just use one of the extra ignition wires i have left over,i have a 200ma 2nd accessory,200ma starter and a 200ma 3rd ignition and i have the 500ma ground when armed.what should i use and would i need a relay?
Posted By: daniel2002p
Date Posted: May 24, 2005 at 7:36 AM
Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | RED / BLUE | IGNITION SWITCH HARNESS* | Ignition #1: | | BLUE/GREEN | IGNITION SWITCH HARNESS | Ignition #2: | | N/A | | Ignition #3: | | N/A | | Accessory: | | BLACK/ GREEN | IGNITION SWITCH HARNESS | Brake Light: | | GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL | Tach Signal: | | TAN (ac) | ANY IGNITION COIL | Parking Lights: | | BROWN (+) | HEADLIGHT SWITCH | Headlights: | | RED / YELLOW (+) | HEADLIGHT SWITCH | Diesel Glow Plug: | | N/A | | Clutch Bypass Wire: | | N/A | | Notes: | | * Vehicle is equipped with Ford's PATS Transponder Theft System. Use Universal Alarm Bypass Module part #2x402 where X can be any number. |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | GREEN/ VIOLET | IGNITION HARNESS | OEM Alarm Disarm: | | PINK/ORANGE (+) | PASSANGER KICK PANEL | Dome Lights/Superv: | | BLACK/ BLUE (+) | HEADLIGHT SWITCH | OEM Horn: | | BLUE (-) | STEERING COLUMN | Power Lock: | | PINK / YELLOW (-) | DRIVERS KICK PANEL** | Power Unlock: | | PINK/GREEN (-) | DRIVERS KICK PANEL** | Trunk Release: | | N/A | | Alarm Input Wire: | | BLACK/ BLUE (+) | HEADLIGHT SWITCH |
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
here is the 05 Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | RED / BLUE | IGNITION SWITCH HARNESS* | Ignition #1: | | BLUE/GREEN | IGNITION SWITCH HARNESS | Ignition #2: | | N/A | | Ignition #3: | | N/A | | Accessory: | | BLACK/ GREEN | IGNITION SWITCH HARNESS | Brake Light: | | GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL | Tach Signal: | | Not red or RED / green AC | ANY IGNITION COIL | Parking Lights: | | BROWN (+) | HEADLIGHT SWITCH | Headlights: | | N/a | N/a | Diesel Glow Plug: | | N/A | | Clutch Bypass Wire: | | N/A | | Notes: | | * Vehicle is equipped with Ford's PATS Transponder Theft System. Use Universal Alarm Bypass Module part #2x402 where X can be any number. |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | GREEN/ VIOLET | IGNITION HARNESS | OEM Alarm Disarm: | | PINK/ORANGE (+) | PASSANGER KICK PANEL | Dome Lights/Superv: | | BLACK/ BLUE (+) | Drivers kick panel | OEM Horn: | | BLUE (-) | STEERING COLUMN | Power Lock: | | PINK / YELLOW (-) | DRIVERS KICK PANEL** | Power Unlock: | | PINK/GREEN (-) | DRIVERS KICK PANEL** | Trunk Release: | | N/A | | Alarm Input Wire: | | BLACK/ BLUE (+) | Drivers kick panel | Notes: | | ** See Note #201 if equipped with OEM Keyless. See Note #203 if no OEM keyless. |
1.8L VVT-i I-4
Date Posted: May 24, 2005 at 2:53 PM
i can see alot of wires going up and down the pillar in the back,are my wires in those bundles?could i find thoise wires in the driver kick panel?
Posted By: JWorm
Date Posted: May 24, 2005 at 8:41 PM
I haven't done an alarm in an 04/05 F150, only remote starts. From what I have heard from others, you can get the true door trigger wires in the running boards. You probably have to get 2 on each side if its a 4 door. You may want look for them under the rear running boards in case the rear door trigger wires come in from the door boot and go straight back.
Date Posted: May 25, 2005 at 8:12 PM
im using a viper 791 on a 2005 f 150,will i have to hook up the tach wire?is it better to just do it?
