mazda 6
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56550
Printed Date: June 05, 2024 at 12:31 PM
Topic: mazda 6
Posted By: IIrjII
Subject: mazda 6
Date Posted: May 27, 2005 at 7:37 PM
I am installin an alarm in a mazda 6. The lock/unlock wire requires a resistor and a relay. How do I wire the relay? Also, will the factory arm/disarm wire relay be wired the same way the lock/unlock relay be wired? Thanks
Posted By: profuse007
Date Posted: May 27, 2005 at 10:32 PM
Lock is negative trigger thru a 1.4K ohm resistor. Unlock is a straight negative trigger. MUST use relays.
85-unlock
86-12volt constant fused
30-ground
87-through a 1.4K for lock
unlock may not need relay.
use keysense to disarm w/o unlocking. as far as what wire form ur unit to use, you need to specify what unit you have. next time, state ur make/yr/model and unit make/model for faster response.
Keysense WHITE/ blue + ignition harness
------------- Houston,TX
