I will try to make this short
I bought the compustar 2w-800 with cm3000 module
Every thing was going ok with the installation and before I finish the violet pre wired to the starter kill stopped giving (-) ground when the system is armed
I examined the cm3000 circuit board for any failures like diodes or relays but every thing looks ok
I went thru the manual and I found out that in program (2) you can change that option to ignition kill? But that doesn't work ether I also can't enter the programming mood 1 or 2 because I need to increase the pulse time on aux1 and aux2
Any help please I spent 2 weeks installing the system and its all to waist if I can't solve this
thanks guys
Sorry, but what exactly do you need help on?
Be careful whose advice you buy, but be patient with those who supply it.
Sorry maybe I was not clear
What I need is
1- How to program the aux1 and aux2 to generate (-) pulse for 40sec instead of 1sec I under stand that it’s possible as the manual says? But the process is some how confusing
2- the violet pre wired to the starter kill relay stopped giving (-) ground when the system is armed how can I fix that so it produce ground (-)like before?
Thank you very much for your time
sory maybe i wasn't clear
wha i deed is
1- how to program the aux1 and aux2 to generate (-) pulse for 40 sec instead of 1 sec i understand that it's possible as the manual says but the process is some how confusig
2- the violet pre wired wire for the starter lill relay stoped giving (-) ground conection when the car is armed how can i fix that so it givis ground conection like before?
thak you very much for your time
sory
what i deed is
thak you very much for your time and sory agane
zotzot wrote:
sory
what i deed is
I would like to know how to program the aux1 and aux2 for more time also. I guess you'll need a programmer. Im not sure. Hopefully
