built in Anti-grind in valet 562t?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59213
Printed Date: May 20, 2024 at 10:57 PM
Topic: built in Anti-grind in valet 562t?
Posted By: oasis475
Subject: built in Anti-grind in valet 562t?
Date Posted: July 11, 2005 at 11:45 AM
hey, Does valet 562t have a built in Anit-grind and starter kill or i have to put an external relay for them to
ORANGE / BLACK (-) ANTI-GRIND OUTPUT/GROUND WHEN ARMED OUTPUT wire
and
ORANGE (-) 500 mA ARMED OUTPUT wire
if the feature is built in then what do i do with these two wires?
thanks alot for you help
BTW the car is 1995 toyota camry
Posted By: chriswallace187
Date Posted: July 11, 2005 at 12:42 PM
If it has it built in it should have both green and purple heavy gauge wires for the starter - the green goes to the key side and the purple goes to the starter side of the cut starter wire.
If it's not built in, use a relay:
85 - ORANGE / black anti-grind output from 562T
86 - constant 12v+
87a - key side of starter wire
30 - motor side of starter wire (also make sure you hook up the remote start's starter output wire on this side).
No need to use the orange ground-when-armed output unless you're doing window control something like that.
------------- C Renner's Auto Electronix
Posted By: kgerry
Date Posted: July 11, 2005 at 2:48 PM
it is a built in feature.......you can program this feature on or off with the Bitwriter.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
