I'm looking for the wiring wiring diagram for a 2005 Ford Explorer, (Eddie Bauer, if it makes a difference)
Could you please post it in the forum and email me at
da_ridge83@yahoo.com if anyone can find the information for me.
Thanx
Constant 12 volts | YELLOW (30AMP) | IGNITION SWITCH HARNESS |
Ignition 12 volts | RED / LT GREEN | IGNITION SWITCH HARNESS |
Starter | RED | IGNITION SWITCH HARNESS |
Dome Light | BLACK/ LT BLUE (+) | IN PASS. KICK OR CLUSTER * |
Trunk Pin Switch | WHITE/ VIOLET | AT CENTRAL SECURITY MODULE ** |
Parking Lamp | BROWN (+) | AT HEADLIGHT SWITCH |
Power Lock | PINK / YELLOW | IN DRIVER'S KICK PANEL |
Power Unlock | PINK/LT GREEN | IN DRIVER'S KICK PANEL |
* May Also Be Found As YELLOW/LT BLUE At Cluster ** CSM Located Behind Passenger Rear Quarter Panel Next To Rear Seat. Pin Switch Wires Rest At Ground And Open When The Doors Open
Negative Pulse Door Locks
Accessories |
Window Up | D\WHT/BLK P\WHT/YEL D\GRY\ORNG P\YEL/BLK @ MAIN SWITCH | |
Window Down | F/TAN/L BLU F/TAN/L BLU R/YEL/L BLU R/RED / BLK | |
Ign Key Warn | LT GREEN/ VIOLET (+) | IGNITION SWITCH HARNESS |
Trunk Release | NONE | |
OEM Horn | YELLOW/LT GREEN (-) | STEERING COLUMN HARNESS |
Headlights | RED / BLACK (+) | AT HEADLIGHT SWITCH |
OEM Alarm Arm | NONE | |
OEM Alarm Disarm | DK GREEN/ VIOLET (-) | IN DRIVER'S KICK PANEL |
Reversal Rest At Ground Power Window
OEM HOOD PIN: NONE OEM ALARM HORN OUT: DK BLUE (+) AT HORNS
Remote Start |
Tach Signal | ANY NOT WHITE/ LT BLUE | AT EACH IGNITION COIL |
Ignition #2 | NONE | |
Ignition #3 | NONE | |
Accessory | DK GREEN/ LT GREEN | IGNITION SWITCH HARNESS |
Neutral Safety | NON-GROUNDING TYPE | |
Brake Light | TAN/BLACK | AT SWITCH ABOVE BRAKE PEDAL |
Reverse Light | BLACK/ PINK (+) | AT REVERSE LAMPS OR REAR BODY HARNESS |
Rear Window Defrost | ORANGE / YELLOW (-) | AT CENTRAL JUNCTION BOX * |
* CJB Located High In Driver Kick Panel
Transponder Bypass
Use IB-PKF-3 ( No Key Required )ByPASS
MO
