’03 Mitsubishi Eclipse, dash lights out
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61176
Printed Date: May 07, 2024 at 10:20 PM
Topic: ’03 Mitsubishi Eclipse, dash lights out
Posted By: skyline_dragon
Subject: ’03 Mitsubishi Eclipse, dash lights out
Date Posted: August 11, 2005 at 9:01 PM
Hey everyone! My friend and I just installed an Autopage 850LCD in his 2003 Eclipse GT and we have a problem. For some reason, the dash lights do not work. What did we do??? It began after we connected the parking lights, or so we think. Any help would be appreciated! Thanks!
Posted By: Satkunas
Date Posted: August 11, 2005 at 9:26 PM
Are you sure you connected to the parklight wire, or did you connect to the dimmer wire? If the latter then you probably blew the dimmer cct and will need to replace it. But check the fuse first.
Posted By: Velocity Motors
Date Posted: August 12, 2005 at 8:54 AM
What wire color and location did you hook up the parking light wire to ?
------------- Jeff
Date Posted: August 12, 2005 at 11:06 AM
We checked the fuse right away and it was fine. GREEN / WHITE wire in the harness next to the fusebox on the driver's side of the dash.
Posted By: OhioMike1101
Date Posted: August 12, 2005 at 6:43 PM
Parking Lights+ GREEN / WHITE + pin 2, 15 pin plug above fuses
Date Posted: August 14, 2005 at 4:05 PM
The wire is right, but the dash lights aren't working for some reason. What do you guys suggest we try? The dash and the AC don't light up.
Date Posted: August 14, 2005 at 4:19 PM
Did you check the fuse with a DMM or just visual ? ------------- Jeff
