just wondering if someone could share some wiring info for an add-on remote start to factory keyless entry for the matrix. i can't seem to find it anywhere.
thank you,
seanw
sean walsh
Do you mean the 2003 Matrix?
You wouldn't want to do a keyless upgrade---range is poor, and the factory remotes don't work with the motor running. Far easier to just do everything off the aftermarket remote.
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | RED | IGNITION SWITCH HARNESS |
Ignition #1: | | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #2: | | | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Ignition #3: | | | N/A | |
Accessory: | | | BLUE/RED | IGNITION SWITCH HARNESS |
Brake Light: | | | GREEN / WHITE | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | | |
Parking Lights: | | | GREEN (+) | IN DRIVER'S KICK PANEL |
Headlights: | | | RED (-) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | | | |
OEM Alarm Arm: | | | | |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | WHITE | IGNITION SWITCH HARNESS |
Starter Kill: | | | RED | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | COMES ON WITH UNLOCK | DOOR TRIGGER IS RED / YELLOW (-) IN DRIVER'S KICK |
OEM Horn: | | | GREEN/ YELLOW (-) | STEERING COLUMN HARNESS |
Power Lock: | | | GREEN (-) | PASSENGER KICK PANEL * |
Power Unlock: | | | BLUE/BLACK (-) | PASSENGER KICK PANEL * |
Trunk Release: | | | BLUE/WHITE (-) | AT RELEASE SWITCH ON DASH |
Alarm Input Wire: | | | COMES ON WITH UNLOCK | DOOR TRIGGER IS RED / YELLOW (-) IN DRIVER'S KICK |
Notes: | | * These wires are connected to passenger door lock cylinder. Test wires using key in door lock cylinder. See Installation Note #201 - Negative Trigger Door Lock Diagram. |
This vehicle is pretty easy and have fun.
