Just got a viper 791
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64121
Printed Date: May 09, 2024 at 4:34 PM
Topic: Just got a viper 791
Posted By: lazyxazianxboi
Subject: Just got a viper 791
Date Posted: October 09, 2005 at 10:45 PM
Well i got everything to work and everything but i wanted to ask if my parking lights are suppose to flash and how many times is it suppose to when my car is remote started......and if they are suppose to do that how do i bypass that?? so my lights don't flash? and it just starts?...thanks in advanced
Posted By: mrcllusb
Date Posted: October 09, 2005 at 11:30 PM
Here's what you gotta do.YOu have to go back into the programming mode.In the programming menu # 3,feature 3-4 right now ur set at the one chirp setting which is the default.You have to go back into the programming and change it to 2 chirps which will change it to constantly on parking lights when remote started
------------- "ole blake"
Posted By: kgerry
Date Posted: October 11, 2005 at 11:39 AM
if you want them on solid instead of flashing then, program it for constant.... if you dont want them on at all then pull the fuse on the white wire.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: blazeronspokes
Date Posted: October 11, 2005 at 6:54 PM
if you pull the fuse on the white wire you won't have parking lights when you arm/disarm the vehicle either.
