crimestopper
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64386
Printed Date: May 31, 2024 at 10:48 PM
Topic: crimestopper
Posted By: dmcollazo
Subject: crimestopper
Date Posted: October 14, 2005 at 5:30 PM
Hi! Had my battery disconnected to do some work. Put cables back on and car sounded like the battery was low(sluggish) It started but really rough. Changed old battery. Now I can't get even a click from the starter. You can hear a tick noise from around the crimestopper module in the dash. It has a kill switch in it. I also activated the alarm---No Blinking Parking Lights! I also unlocked the drivers door manually and opened it and No Horn (alarm sound) also opened the hood, and again nothing. Could the alarm be on the fritz and messing with my starter, cause I can get the engine to crank if I hot-start it straight from the battery to the starter. Any help can be useful. Thanks!
------------- d collazo
Posted By: 78musicman
Date Posted: October 14, 2005 at 6:01 PM
new battery is dead.
------------- colorado tap the rockies
Date Posted: October 14, 2005 at 6:23 PM
no actually the battery is not dead because I am able to hot start the enging straight from the battery to the starter. I keep hearing a click in the dash board under the steering wheel. I also the the same click if I hit the door lock button up when the locks are already unlocked.
Posted By: mrcllusb
Date Posted: October 14, 2005 at 7:09 PM
The click sound you hear is the relay..
------------- "ole blake"
Posted By: mrcllusb
Date Posted: October 14, 2005 at 7:10 PM
Check all of your fuses.Alarm and car
Date Posted: October 14, 2005 at 9:37 PM
Thank you all for your replies! which relay should I check? Already checked the starter relay in the fuse box. Actually put a new one in.No change though. It's a 96 T&C 3.8. It has the crimestopper rs900iv. But it also has a factory alarm with the kill switch. There are a bunch of relays under the dash by the E-Brake also. Will try the battery thing also. Thanks again!
