95 Chrysler LHS alarm wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64619
Printed Date: May 21, 2024 at 12:14 PM
Topic: 95 Chrysler LHS alarm wiring?
Posted By: Jay22
Subject: 95 Chrysler LHS alarm wiring?
Date Posted: October 18, 2005 at 8:03 PM
Okay My car got stolen so when I got it back I purchesed a Clifford Arrow 5 alarm system.
I drive a 95 Chrysler LHS with factory keyless and alarm...how would I override this?
Wiring for alarm...
Also can someone match up the wiring for me.
The only ones I dont understand totally light polarity and outputs(white wire) Instant trigger and (-)acc output A(is this for trunk pop) and output when armed
Thanks a ton....
Jay
Alarm wiring
1 black- chasis ground
7 blue- (-) instant door trigger
8 violet- (+) door trigger
9 Green- (-) door trigger
10 Red- (+)12v power input
11 Brown- (+) siren output
12 WHITE/ red- Light flash Polarity
13 white- Light flash output
14 white- Light flash output
15 BLACK/ white- (+) dome light output
16 RED / white- (+) acc output
17 Orange- (-) output when armed
18 Yellow- (+) ignition
plug in Door lock pin
Green
Blue
Here is the wiring for the car
1995-97 Chrysler LHS Security Information
Constant 12V+ Pink/Black Ignition Switch Harness
Starter Yellow/Gold Ignition Switch Harness
Ignition Dark Blue Ignition Switch Harness
Ignition 2 RED / White 12GA Ignition Switch Harness
Ignition 3 RED / White 18GA Ignition Switch Harness (Air Bag Light)
Accessory BLACK/ Orange Ignition Switch Harness (Heat/AC)
Tach Red WHITE/ Black (PCM Passenger's Wheel Well 2 Cylinder Setting)
Neutral Safety Wire BLACK/ Light Green Switch on Driver's Side or Transaxle
Brake Switch White or WHITE/ Tan Brake Switch
Trunk Release BLACK/ White (+) Switch in Glove Compartment
Trunk Pin BROWN / Black (-) Driver's Kick Panel
Parking Lights BLACK / YELLOW Driver's Kick Panel
Head Lamp Green Light Switch
Hood Pin n/a
Factory Disarm Light GREEN/ Orange (-) High Driver's Kick Panel
Door Trigger Yellow (-) Driver's Kick Panel White 20 Pin Connector
Door Lock ORANGE / White Behind Fuse Panel at Door Lock Relays
Door Unlock Pink/Purple Positive Trigger
Horn Wire BLACK/ Red (-) Horn Relay in Fuse Panel
Dome light supervision tan(-)
Windows Up LF=Light Blue/Gold, RF=BROWN / White, LR=Blue/White, RR=Gray/Black
Windows Down LF=WHITE/ Gold, RF=PURPLE / White, LR=RED / Black, RR=GREEN / WHITE
Posted By: mo12v
Date Posted: October 18, 2005 at 8:42 PM
Not sure but I think 1995 wires you have are different from mine..... METER ALL wires..........to be sure Others may add to this Basic Install.......... TRY: 1 black- chasis ground = Yep 2 not used =x 3 not used =x 4 not used =x 5 not used =x 6 not used =x 7 blue- (-) instant door trigger = tan & tan/red : driver kick panel : Tan gets drivers door, tan/red gets pass. doors. Tap both wires and diode isolate. 8 violet- (+) door trigger =x 9 Green- (-) door trigger = tan & tan/red : driver kick panel : Tan gets drivers door, tan/red gets pass. doors. Tap both wires and diode isolate. 10 Red- (+)12v power input = pink/black or red (20A) 11 Brown- (+) siren output 12 WHITE/ red- Light flash Polarity = pink/black or red (20A) 13 white- Light flash output = BLACK / YELLOW ::driver kick panel 14 white- Light flash output = BLACK / YELLOW ::driver kick panel 15 BLACK/ white- (+) dome light output 16 RED / white- (+) acc output = BLACK/ white 17 Orange- (-) output when armed = Starter Disable Relay 18 Yellow- (+) ignition = dk. blue/gold dots
plug in Door lock pin Green = ORANGE / white + RELAY Can also pulse Factory Disarm ( if U have ) with Negative = lt.GREEN/ orange 20ga : either kick Blue = pink/purple + RELAY
------------- MO
Posted By: Jay22
Date Posted: October 18, 2005 at 8:54 PM
Now for the relays which do I buy and how would that get wired up....and what diode to use..
I am a moron when it comes to alarms but great with audio so i feel like a moron for asking these Q's but thanx alot for the info the wiring looks the same.
Jay
Posted By: mo12v
Date Posted: October 18, 2005 at 10:28 PM
You can use 1N4001 diode 3 SPDT Relays:
Relay 1 LOCK: PIN 87 = ORANGE / white Lock wire PIN 87a = XX PIN 30 = Constant 12 volt ( + ) : pink/black or red (20A) PIN 85 = Negative Lock Output from Clifford PIN 86 = Constant 12 volt ( + ) Relay 2 UNLOCK: PIN 87 =Pink/purple Unlock wire PIN 87a = XX PIN 30 = Constant 12 volt ( + ) : pink/black or red (20A) PIN 85 = Negative UNLock Output from Clifford PIN 86 = Constant 12 volt ( + ) Relay 3 DISARM PIN 87 =lt.GREEN/ orange 20ga PIN 87a = XX PIN 30 = GROUND PIN 85 = Negative UNLock Output from Clifford PIN 86 = Constant 12 volt ( + ) ------------- MO
Posted By: Jay22
Date Posted: October 18, 2005 at 11:12 PM
Also sorry one more lol should i cut these wires and hook them to the relay or splice them or does it matter???
Thanks and sorry wont bug u anymore...I wish u lived around here I would owe ya a few beers for all this work u did for me....I appreaciate it alot
Jay
Posted By: redpeppers
Date Posted: October 18, 2005 at 11:38 PM
try this diagram......it says u dont need a relay for the lock and unlock just postive locks.....u only need a relay if the system u r installing does have postive lock and unlock outputs https://www.directechs.com/directwire/wire_body.asp?action=select&yr=1611&product=Remote%20Start ------------- Where theres is a wire there's a way.
Posted By: Jay22
Date Posted: October 18, 2005 at 11:50 PM
So in total I will need 4-20 amp fuses.(relay 1, relay 2, power and light flash polarity) 3 relays and 2 diodes.
If i dont need the relays do i just hook the alarm wires straight to the power lock and unlock positive??
Thanks Jay
Posted By: secureauto
Date Posted: October 18, 2005 at 11:52 PM
According to Clifford wiring diagram, the blue wire on the 3 pin harness can be used as a positive lock output and green can be used as a positive unlock output.
------------- ASE Certified
