Wiring Diagram for 2001 BMW 530i
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6468
Printed Date: May 04, 2024 at 9:24 PM
Topic: Wiring Diagram for 2001 BMW 530i
Posted By: Ry328is
Subject: Wiring Diagram for 2001 BMW 530i
Date Posted: December 10, 2002 at 8:30 AM
I'm thinking about installing a remote starter for a 2001 BMW 530i. Can someone please give me the wiring diagram for this car? Thanks, Ry
Posted By: 10nesne1
Date Posted: December 10, 2002 at 9:58 AM
Remote Starter Wiring Colors and Notes | Function | | | Vehicle Color | Location | Start: | | | BLACK / YELLOW | IGNITION SWITCH HARNESS * | Ignition #1: | | | GREEN | IGNITION SWITCH HARNESS | Ignition #2: | | | SECOND GREEN | IGNITION SWITCH HARNESS | Ignition #3: | | | N/A | | Accessory: | | | BLACK / YELLOW | IGNTION SWITCH HARNESS | Brake Light: | | | BROWN / GRAY | AT SWITCH ABOVE BRAKE PEDAL | Tach Signal: | | | BLACK / YELLOW OR BLACK | AT BACK OF INSTRUMENT PANEL * | Parking Lights: | | | BLACK | AT LIGHT SWITCH ** | Headlights: | | | | | OEM Alarm Disarm: | | | ARMS WITH LOCKS | | OEM Alarm Arm: | | | DISARMS WITH UNLOCKS | | Diesel Glow Plug: | | | N/A | | Clutch Bypass Wire: | | | N/A | | Notes: | | * This vehicle is equipped with a transponder immobilizer system. See Installation Note #144 - Bypassing Transponder Theft Systems. ** Cut This Wire In Half. Connect One Side To Pin #87a Of A Relay And Connect The Other Side To Pin #30 Of The Same Relay. Wire Pin #85 To Ground And Connect Pin #86 To The Yellow Light Wire Coming From The AutoCommand. When The Wire Is Interrupted, The Parking Lights Will Come On. |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | | Vehicle Color | Location | Constant +12 Volts: | | | RED | IGNITION SWITCH HARNESS | Starter Kill: | | | BLACK / YELLOW | IGNITION SWITCH HARNESS * | Ignition +12 Volts: | | | GREEN | IGNITION SWITCH HARNESS | Dome Lights/Superv: | | | BLUE/RED (+) | AT MAIN DOME LAMP SWITCH *** | OEM Horn: | | | | | Power Lock: | | | BLUE/RED (+) | INSIDE OF DRIVER'S DOOR **** | Power Unlock: | | | BLACK/ WHITE (+) | INSIDE OF DRIVER'S DOOR **** | Trunk Release: | | | BRAY/BROWN (-) | AT RELEASE SWITCH IN DRIVER'S KICK | Alarm Input Wire: | | | BLUE/RED (+) | AT MAIN DOME LAMP SWITCH *** | Notes: | | *** Use A Relay To Reverse The Polarity To Negative. **** See Installation Note #202 - Positive Trigger Door Lock Diagram. |
