Do I Have Factory Anti-theft???
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6536
Printed Date: May 28, 2024 at 10:40 PM
Topic: Do I Have Factory Anti-theft???
Posted By: miner1no
Subject: Do I Have Factory Anti-theft???
Date Posted: December 11, 2002 at 2:05 PM
With a 96 Cavalier how would one determine if a security bypass module is needed for a remote starter??
------------- Miner
Posted By: mxxmikexx
Date Posted: December 11, 2002 at 2:48 PM
the 96 has passlock 1. You should have a light that comes on when you start the car that says "security" and after a few seconds of starting the car the light will shut off.
Posted By: jrilla
Date Posted: December 11, 2002 at 2:52 PM
Sorry I was typing this while the previous response was posted: If you have a light on you dash board that reads: "Anti-Theft", that turns on before you start your car and turns off shortly after you the car has been started, then you have a Passlock I anti theft device that you need to bypass. I would use the single relay with a resistor method to bypass for that car. It will basically permanently bypass the device though. ------------- J Rilla
Owner/Installer
Posted By: miner1no
Date Posted: December 12, 2002 at 6:44 PM
Yep I've got to bypass. Forgive my ignorance for I am a Power Plant Controls Tech midnighting as a remote car starter installer for my betty. Where is the relay installed? What type of resistor is required? Sounds easier to disable the factory anti-theft all the time. I want to avoid buying another module. ------------- Miner
Posted By: jrilla
Date Posted: December 12, 2002 at 8:41 PM
You need to pull the shroud off the steering column and look for 3 thin gauge wires: Yellow, Black and White. You will need a digital multi meter (DMM), a 30amp relay and a resistor. I would save yourself a trip to the store and buy a 10k ohm Trimpot so you can just dial in the resistence. Then you need to strip back the Black wire a little, start the car and then cut the yellow wire. Measure the resistence between the key side of the yellow wire and the black wire that you stripped back. record the resistence then reverse the DMM leads and record that resistence. You can shut the car off and then look for the bulb test wire which should be black, and it can be found in the same plug as the two Red wires that supply 12v+ to the ignition switch. dial the higher of the two resistences into the trimpot and then hook up the relay as follows: Pin 87 goes to the black bulb test wire, pin 30 goes to the black wire that you stripped back earlier (called the passlock ground wire), pin 87a goes to one side of the trimpot and the other side of the trimpot goes to the computer side of the yellow passlock wire, Pin 86 goes to a good chassis ground, and pin 85 goes to the starter wire of the car and the remote starter. If you need a diagram or any more help let me know. Good luck. It is not as difficult as it sounds. ------------- J Rilla
Owner/Installer
Posted By: miner1no
Date Posted: December 13, 2002 at 6:15 AM
Doesn't sound to bad. What's the quickest way to source a 30 amp relay and a 10K pot? And links or suggestions? ------------- Miner
Posted By: jrilla
Date Posted: December 13, 2002 at 6:19 AM
You can get a trimpot and a relay with a wire harness from radio shack. Try and get a trimpot that is tight and will not adjust if accidently bumped. I always put my pots in box that my relays come in to keep them from being bumped. Radioshack relays dont come in a box, but see what you can do.
Owner/Installer
Posted By: Formula
Date Posted: December 18, 2002 at 12:30 AM
Anyone knows where I can find the purple wire that's going from the Theft Deterrent relay to the starter? I rather use this wire for the "starter" wire of my remote starter installation than the yellow starter wire at the ignition harness. All descriptions on the web show it located behind the glove box to the right, next to the hatch relay and the A/C valve. However, my car doesn't have it there. Maybe, because in 1997/1998 they changed the location? Anyone could help? Or, is there an easy way to indetify the yellow starter wire around the steering column or where it goes and tap into that one? Thank you. (I already installed the Vats/Passkey bypass) I have a 1998 Formula V-8, 5.7L with factory alarm.
------------- 1998 Formula V-8 5.7L
Posted By: miner1no
Date Posted: December 20, 2002 at 12:37 PM
Made up a drawing and got the wiring diagram out of the Hayes Manual. Everything makes sense except... the need to have the bulb test wire picked up to the black Passlock ground when the remote starter goes hot?? ------------- Miner
Posted By: jrilla
Date Posted: December 20, 2002 at 1:26 PM
I dont get it either but that's what you have to do because that's how it works.
Owner/Installer
Posted By: miner1no
Date Posted: December 20, 2002 at 1:54 PM
Do I cut the bulb test and connect it relay to ingnition side of Wire? Do I cut the blk passlock wire or T into it?
------------- Miner
Posted By: miner1no
Date Posted: December 23, 2002 at 11:01 AM
J Rill...thanks for the help....it works like a charm. Could I put a switch in that would put the factory resistor back into play. Like if the trimmer drifts due to temperature? ------------- Miner
Posted By: jrilla
Date Posted: December 26, 2002 at 3:24 PM
If you are concerned about losing resistence, you can buy a resisitr within 5% of the value and put that in there. I know you already got it working, so you must have answered the two above wuestions about cutting or tapping, but the only wire you cut is the yellow wire and you only tap the bulb test wire and the passlock ground wire (Black). Yes, If you want to you can put a SPDT switch between the computer side of the yellow wire and the resistor and hook it up with the computer side in the middle, the trimpot on one side and the key side on the other. Radio shack sells them. Let me know if you need more info. ------------- J Rilla
Owner/Installer
Posted By: miner1no
Date Posted: December 27, 2002 at 6:20 AM
J.Rilla..FYI....96 Cavalier....must have changed the color code on the passlock. The passlock wires are in a ribbon cable with two black wires and one black with a white stripe...white strip is white, 2nd black wire is the black one, 3rd black wire is the yellow. ------------- Miner
Posted By: jrilla
Date Posted: December 27, 2002 at 7:43 AM
Yeah, there are three different color schemes: Trucks have Yellow, ORANGE / Black, and RED / White. I have never run into the all black wires though. The 96 cavalier I did didn't even have a passlock I. All the other cavaliers I have done had the yellow, black and white.
Owner/Installer
