remote starter 2004 saturn ion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65738
Printed Date: May 08, 2024 at 5:02 AM
Topic: remote starter 2004 saturn ion
Posted By: derrick600
Subject: remote starter 2004 saturn ion
Date Posted: November 06, 2005 at 8:58 PM
I've been messing with this for a couple days now. I have used the install diagram off this site perfect. Everything works with the remote starter but the starter. When I run it, the ignition and accessories firer up but then no starter. It doesn't even attempt to turn over the car.
Could this be because I am not setting the security bypass module corectly? Any other dumb mistakes?
Bypass from BYPASSKIT.COM and starter from CARVOX
Thanks for any help...
Posted By: redpeppers
Date Posted: November 06, 2005 at 9:19 PM
what is the model number of the bypasskit u used?
------------- Where theres is a wire there's a way.
Date Posted: November 07, 2005 at 6:25 AM
It is the Ion specific one. PLXR 01.02.01
The default is the Ion setting and I think I did set the resistor code correctly. I tried doing it2 seperate times.
Posted By: Velocity Motors
Date Posted: November 07, 2005 at 7:26 AM
We need more information from you. If you tell us wire for wire on what you connected to on the PLXR, we can help you find the problem. If it's in the wiring, then we can help you figure out the proper way to wire it, if it's a programming issue, then that is easy to get you on the right track.
------------- Jeff
Date Posted: November 07, 2005 at 1:02 PM
Wires come from green ignition harness
Ignition: pink PLXR to blue Ion and pink Remote Start
Starter: violet PLXR to violet Remote Start
Cut white wire ION: blue PLXR to ECM side
pink/white to key side
Bypass Output: brown PLXR to blue/white Remote Start
Accessory: brown ION to access from remote start (orange)
