Air bag light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66830
Printed Date: June 05, 2024 at 12:19 PM
Topic: Air bag light
Posted By: MJAYCO
Subject: Air bag light
Date Posted: November 22, 2005 at 5:54 PM
I just installed a remote starter on a 2001 Kia sportage. I unplugged the knee airbag to get at the wires now the airbag light is flashing. Is there a way to reset this light without a trip to the dealer? I tried disconecting the battery for abut a half hour but it did not work. Thanks for any help. Mike
Posted By: 05gt
Date Posted: November 22, 2005 at 7:28 PM
usually when you plug the wire back in, it should get rid of the light if you have already disconnected the battery with no luck, more thanlikely you will have to go to the dealer to get the code removed, unless you know someone with a code reader
Posted By: redpeppers
Date Posted: November 22, 2005 at 11:55 PM
in the future.....disconnect the batt. first before unpluging airbag wires......but i am sure u know that now.
------------- Where theres is a wire there's a way.
Posted By: extreme1
Date Posted: November 23, 2005 at 9:33 AM
never ever turn on the ignition when you have airbag wires unplugged.
let this be a lesson, you're vehicle needs a trip to the dealer.
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: 05gt
Date Posted: November 23, 2005 at 3:48 PM
not trying to be an ass here but I had the airbag plug unplugged on my car when I had the passenger seat out and I drove my car for about a couple of days It is a 2005 Mustang GT
Posted By: slammedb5
Date Posted: November 23, 2005 at 6:08 PM
pull the cluster and yank the srs bulb
------------- EK Civic
security
no audio
Posted By: extreme1
Date Posted: November 23, 2005 at 8:19 PM
ass :p
my 06 Jetta, there was a loose connection, didn't even come unplugged, under my passenger seat, tripped an airbag light.
you breath on an airbag wire in my car it'll trigger a light. ------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: tragik
Date Posted: November 23, 2005 at 8:42 PM
You can usually rest the airbag light in most cars by disconnecting the battery.
If that doesn't work, leave the key in the on position and disconnect the battery. Then reconnect the battery withthe key on too. This should wrok. It should work too. I spelled it wrok to show how serious I am. Ha
------------- Northstart.....or start it your damn self.
Posted By: 05gt
Date Posted: November 23, 2005 at 8:49 PM
bobk]0 wrote:
gt, Having the seat out will set the seatbelt light. Do you have side air bags as part of the seat, the Kia does If you do then the AIR BAG light will set.
there are side airbags in the car, I looked on the dash and it was the SRS light that was on when it was unplugged under my passenger seat there are two plugs, one of the plugs was airbag stuff, and the other plug does everything else
Posted By: chris354
Date Posted: November 23, 2005 at 9:42 PM
Some brands of cars will reset next time key is turned on and no fault found, some have to be reset by the dealer.
Posted By: redroc
Date Posted: November 24, 2005 at 2:52 AM
On a Kia it will have to go to the dealer,disconnecting the battery won't work.
Posted By: kgerry
Date Posted: November 24, 2005 at 7:10 PM
from Wire Magic VERY IMPORTANT: The knee bolster below the steering wheel contains an airbag. Remove the fuse marked airbag in the fusepanel in the DKP before disconnecting the airbag. If the Airbag is disconnected with the fuse in place, it may cause the SRS light to come on. If this happens, you must bring the vehicle to a dealer to have the code erased. and Directechs If equipped with a knee air-bag system, unbolt without disconnecting to access wiring. i never unplug the knee bolster airbag... just slide it over to the side towards the center console and do my wiring.... ------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: joe_1
Date Posted: November 25, 2005 at 11:29 AM
some of you boys are dodgey, allways discharge the system for 30 mins before even attempting to unplug or remove an srs component, most new cars srs light stays on now even if the wires are unpluged and connected correctly, i know it is a pain in the ass, a trip to the dealer to get reset, lucky enough i have equipment to reset the system. ------------- i am also a technician so if you have any engine trouble let me know, and i will do my best to help.
