Hey There guys n gals!
if you were to start fresh with a new car which alarm would you pick?
There are some new units out there and I wanted to see if there was something that you preferred over my current choice, which is a 791xv
My main concerns are;
Remote start, (highly prefer lcd with confirmation)
Turbo Timer
and ability to add additional accessories.
Anything you recommend me considering?
I plan on adding the following accessories;
if DEI, 530T remote start
Extender
522T trunk release solenoid.
508d dual zone.
520t battery backup
and a few extra piezos
Thanks in advance!!
BTW Here is the car it is going into.
1996 Eagle Talon TSI AWD
If you are using mostly DEI accessories it's easier to add them to a DEI alarm, I would say that the viper is a good choice, maybe if you don't want a two way consider the new clifford G5, its got a better range, but no confirmation.
Not quite, they were just, "In theories" if I did choose the 791xv
If I chose a different "brain" I would get similar accessories that correspond with the correct brand.
Clifford G5.5.....
I did the 785XV in my car, not a bad piece at all at it's pricepoint. I find turbo timer to be rather useless is you are using good oil (resists coking on the turbo shaft bearings/bushings) A decent synthetic oil is the way to go... Motul rocks.
Gus
Clifford AVG 5.5 all the way.... ETA Feb 06
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Arg..... Dang.... Anyway to get a prerelease?
:) I know my car will not do well without prewarming. I am really concerned, I can feel its like sludge when she starts cold (it was damn cold today and only is going down, chicago)
damn. damn. Feb 06 yarrrggg....
