2005 chevy avalanche, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67534
Printed Date: June 01, 2024 at 3:19 PM
Topic: 2005 chevy avalanche, remote start
Posted By: 05gt
Subject: 2005 chevy avalanche, remote start
Date Posted: December 03, 2005 at 1:41 AM
Some of the wiring directions I have access to say, some of the ignition and the starter wires are smaller gauge at the ignition harness I look at the ignition harness right at the key cylinder and there are 8 wires coming out of it and all are thicker gauge can anyone help me out
Posted By: NowYaKnow
Date Posted: December 03, 2005 at 1:45 AM
You are looking for your normal GM truck thicker wires.. Nothing out of the ordinary.
Mike
Posted By: 05gt
Date Posted: December 03, 2005 at 1:50 AM
I have already installed the audiovox ax901 on this vehicle, but I can't get it to remote start plus the airbag light is on, i connected ignition 1 to pink, ignition 2 to white, and accessory 1 to orange, I also have had accessory 2 to brown, but the thing still doesn't start I used the 456G that works perfect, for bypass I used the 555L I wired passlock ground to black on the ignition switch, I cut the yellow wire in half, and connected properly, as I have done lots of these at work, I started the car with key to let the bypass program, turned it off after about 10 seconds (is this the proper way of doing this?) when I go to remote start the vehicle it tries to start and basically starts but then immediately it dies can someone help
Posted By: 05gt
Date Posted: December 03, 2005 at 2:10 AM
someone please help, as the customer is on his way back
Posted By: techfiftyfive
Date Posted: December 03, 2005 at 4:53 AM
Did you get the right tach wire? Try properly grounding your passlock ground rather than wiring it to another wire.
Posted By: Mike M2
Date Posted: December 03, 2005 at 8:12 AM
You are using the wrong ground for the 555L. It should be ORANGE / black not black on an Avalanche....
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Velocity Motors
Date Posted: December 03, 2005 at 8:35 AM
The Passlock system is not getting the proper resistance from the 555L module. Ensure that the ground out when running wire is receiving a (-) pulse from the RS unit & that your ground on the RS unit is solid to a clean & paint free surface on the vehicle.
------------- Jeff
Posted By: 05gt
Date Posted: December 03, 2005 at 11:37 AM
there isn't an ORANGE / black wire on this vehicle, there is a black, yellow and RED / white
Posted By: 05gt
Date Posted: December 03, 2005 at 11:41 AM
anyone know on the audiovox ax901 which is the proper (-)ground out when running wire, or the (-)Status wire
Posted By: 05gt
Date Posted: December 03, 2005 at 12:42 PM
ttt
Posted By: kgerry
Date Posted: December 03, 2005 at 1:10 PM
a 457G would solve all your problems PLUS turn on his heated seats etc... i did 2 05 C/Ks yesterday and used the 457G, but i'm pretty sure the ORANGE / black passlock ground was there.....also, the wires are all thicker even tho some wiring programs say to look for smaller gauge wires....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: 05gt
Date Posted: December 03, 2005 at 1:12 PM
yah I got all wires hooked up properly, I am just trying to find the ground when running output from the alarm brain (the proper one) or how I could wire this
Posted By: kgerry
Date Posted: December 03, 2005 at 1:16 PM
grab a meter and meter them till you find the one that is sending out a negative during RS and drops it when the unit is shut down.... quite simple really....
Owner/Installer
Classic Car Audio
since 1979
Posted By: 05gt
Date Posted: December 03, 2005 at 1:20 PM
done that already and I do have the right wire then does anyone know if this truck is passlock 2 or 3
Posted By: kgerry
Date Posted: December 03, 2005 at 1:28 PM
PL II it's not a diesel is it? ------------- Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: 05gt
Date Posted: December 03, 2005 at 1:30 PM
nope, still have problems with it, it will start but won't stay running
Posted By: kgerry
Date Posted: December 03, 2005 at 1:35 PM
is the padlock illuminating up on the cluster? that will denote a passlock issue.... i never had any problems with any of the ones i've done....
Owner/Installer
Classic Car Audio
since 1979
Posted By: 05gt
Date Posted: December 03, 2005 at 1:38 PM
when I remote start the vehicle the passlock light turns on, but when the vehicle dies the passlock light turns off
Posted By: Mike M2
Date Posted: December 03, 2005 at 4:03 PM
Sorry, you are right there is no ORANGE / black anymore in the Avalanche, just looked it up on the DEI website.They switched the ground wire to black in 2004. Are you sure you have the right yellow and the right black. I know some Tahoes have more than one yellow in the harness, did the security light come on when you cut it? Remove the shroud and Trace the three passlock wiresfrom the top of the key cylinder to make sure. They should be yellow, black and RED / white(not used)....
Tech Manager
CS Dealer Services
Posted By: Mike M2
Date Posted: December 03, 2005 at 4:17 PM
Just to help clarify a little. 555L wires, Red to red 12v, pink to ign. pink, yellow to switch side yellow, yellow black to car side yellow, Blue/black to neg output when remote started(i know on a Pursuit Avox it's lt. blue). I'd double check all this. Also, nothing on BLACK/ white and voilet, right? ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: 05gt
Date Posted: December 03, 2005 at 4:21 PM
yep, wired exactely as you have said, I am getting the wires right at the ignition switch so I don't have to trace anything
