APS-686 in a 02 Sante Fe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67586
Printed Date: May 28, 2024 at 10:01 PM
Topic: APS-686 in a 02 Sante Fe
Posted By: shmoove77
Subject: APS-686 in a 02 Sante Fe
Date Posted: December 03, 2005 at 7:47 PM
Yellow/Black tracer wire + 12 volt alarm by pass Output You must disconnect the ignition input of the alarm from any other wire that is presntly connected to the vehicle.......What does that mean ???? Does anyone know if the park lights are a chassis ground sysytem ?? Is there any good diagrams for this vehicle out there ? Thnaks ------------- Shawn
Posted By: Mike M2
Date Posted: December 03, 2005 at 7:52 PM
That means you need to disconnect the ignition wire from your alarm and connect it to the yellow/black instead. The lights can be had either positive or negative. Negative is white at the light switch, positive is GREEN/ orange at the fuse box.
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: December 03, 2005 at 7:55 PM
Thanks....This thing has a factory alarm....Also this is my first remote start install...thought I would give it a whirl
------------- Shawn
Posted By: Mike M2
Date Posted: December 03, 2005 at 8:09 PM
Ok, this will be the 3rd time to try this, lets see if it works.... 12volts
| red and orange
| ignition harness
| Starter | blue | + | ignition harness | | Second Starter | N/A | | | | Ignition | blue | + | ignition harness | | Second Ignition | pink | + | ignition harness | | Third Ignition | N/A | | | | Accessory | green | + | ignition harness | | Second Accessory | N/A | | | | Keysense | brown | + | ignition harness | | Power Lock | yellow | - | driver kick, white 22 pin plug | | Power Unlock | WHITE/ black | - | driver kick, white 22 pin plug | | Lock Motor | gray | 5wi | driver kick, white 22 pin plug | | Unlock Motor | white | 5wi | driver kick, white 22 pin plug | | Parking Lights+ | GREEN/ orange | + | fuse box, 15 pin plug | | Parking Lights- | white | - | headlight switch | | Hazards | green (only w/fac. alarm) | - | ETACS, 12 pin plug | | Turn Signal(L) | pink | + | steering column | | Turn Signal(R) | gray | + | steering column | | Reverse Light | blue/black | + | fuse box, top right plug | | Door Trigger | yellow | - | fuse box, 8 pin plug | | Dome Supervision | use door trigger | | | | Trunk/Hatch Pin | BLACK/ orange | - | fuse box, 15 pin plug | | Hood Pin | pink | - | ETACS, 12 pin plug | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | factory remote only | | | | Factory Alarm Disarm | factory remote only | | | | Disarm No Unlock | disarms with remote start | | | | Tachometer | WHITE/ black or blue | ac | ECM | | Wait to start | N/A | | | | Brake Wire | GREEN/ black | + | brake pedal switch | |
Tech Manager
CS Dealer Services
Date Posted: December 03, 2005 at 8:19 PM
One more question then I'm done....Thank you for all the help so far. Will I have to disarm the factory alarm before I use the remote start to start it ? ------------- Shawn
Posted By: Mike M2
Date Posted: December 03, 2005 at 8:23 PM
Nope! It should happen on it's own.... ------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: December 03, 2005 at 8:30 PM
So how do I find the ignition wire on the factory alarm ?
------------- Shawn
Posted By: Mike M2
Date Posted: December 03, 2005 at 8:33 PM
Why would you need it? It arms only with the remote, diarms only with the remote or when the ignition is turned on. You really don't need to worry about the factory alarm at all....
Tech Manager
CS Dealer Services
Posted By: Mike M2
Date Posted: December 03, 2005 at 8:35 PM
Oh, i see, the bypass says...... Don't worry about it, just don't hook up the yellow/black... ------------- Mike M2
Tech Manager
CS Dealer Services
Ah I see...that is why I paint them and not install alarms ------------- Shawn
Date Posted: December 03, 2005 at 8:37 PM
Thank you your info really helped me out
------------- Shawn
Date Posted: December 05, 2005 at 5:03 PM
What isd the correct way to splice the wires in ? I've been told diffrent things... ------------- Shawn
