Hey Everyone,
I am new to the forums. Just wondering if anyone could help me on instructions or info on how to install a nitro bmw 2way alarm on 1993 BMW 325is. Thanks to anyone that can help me out.
First, if you havent been trained to put in an alarm I wouldnt try it yourself . But if you want to heres the techsheet for it.
12volt- RED / wht or red + ingition harness
starter-blk / YELLOW or blk + ignition harness
ignition- green + ignition
power lock- WHITE/ red + The alarm plug is a black 12 pin plug located just behind the glove box. It is mounted with the pins facing you atop a vent just to the left of the body computer. Other wires at the alarm plug are: 12V- RED / white; Accessory- PURPLE / white; Siren- BLACK/ blue; Ground- BROWN / orange. Do not use the power sources at the alarm plug to operate high-current devices. The other side of the siren wire is mounted in a 2 pin plug at the passenger rear corner of the engine compartment. The other wire in the plug is a brown ground wire. DEI recommends attaching the siren at this point.
power unlock- blue/red + factory alarm plug
parking lights-blue/green - factory alarm plug
door trigger-Door triggers are BROWN / gray for the drivers front door, BROWN / blue for the passenger front door, and BROWN / black for the rear doors (if equipped). Use all three wires and diode isolate each. in factory alarm plug
Chad
Basic certified
Install Sr. at Best Buy
hey thanks for the help. since my car is manual i won't be using the auto start option with the alarm. basically i just want the alarm so i don't gotta bother using the key to open the doors. Yea my factory controlls broke and the dealership wanted 110 for the damn remote so i was like I rather just get a whole new alarm then.
I am confused. There are a couple of wire diagrams for my car. Which one is the right one for a 1993 BMW 325is? I had the factory alarm in my car but I am upgrading to the 2 way nitro
