autopage rs-655 remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68187
Printed Date: May 31, 2024 at 10:48 PM
Topic: autopage rs-655 remote starter
Posted By: daaaz
Subject: autopage rs-655 remote starter
Date Posted: December 12, 2005 at 5:45 AM
i installed an autopage rs-655 alarm remote starter a few months ago everything worked fine up until yesterday.i can arm and disarm the alarm and unlock the doors but no remote start i can start the car with the key but not with the remote i can go into the remotestart program mode i reset the tachless mode reprogrammed the remotes and all the features for remote start still no power on remote starterwhen button is pressed need help please....thanks in advance.
Posted By: 78musicman
Date Posted: December 12, 2005 at 4:56 PM
Not to sound bad,but if you installed this then you are very capable of troubleshooting it.Multimeter,fuses,hoodpin,brakeswitch,bad remote,bypass problem,ground during R/S,bad ground,is it geting power during remote start ect.......If someone else installed it then take it somewhere.I installed mine and could be the best person to troubleshoot it.
------------- colorado tap the rockies
Posted By: daaaz
Date Posted: December 12, 2005 at 7:00 PM
no power during remote start checked fuses they're not blown
Date Posted: December 13, 2005 at 6:01 AM
what does it do?Dash light up or just nothing.On my other truck sometimes you would have to wiggle the hood pin .Disconnect it from any kind of ground(hoodpin).
Posted By: daaaz
Date Posted: December 13, 2005 at 7:09 PM
no dashlights or acc. during power up just dead remote start but alarm still work goes off an everything .the remote starter worked for a few months just fine i have to pull everything back out and check all connecters. you don't think the remote starter is blown or maybe bad ground
Posted By: OhioMike1101
Date Posted: December 13, 2005 at 7:39 PM
daaaz] wrote:
strong>no dashlights or acc. during power up just dead remote start but alarm still work goes off an everything .the remote starter worked for a few months just fine i have to pull everything back out and check all connecters. you don't think the remote starter is blown or maybe bad ground
It can only be one of the following: Bad Brain Hood Pin BLACK/ white wire (ground toggle) Fuses Need to relearn tach Brake Wire
