2000 Tahoe disarm wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68224
Printed Date: May 01, 2024 at 6:48 PM
Topic: 2000 Tahoe disarm wire?
Posted By: russ lund
Subject: 2000 Tahoe disarm wire?
Date Posted: December 12, 2005 at 5:06 PM
Hey guys I've been looking all over hell for the factory disarm wire in this witch.I can't get it at pin 3(lt green) in purple plug at the bcm.And I can't find a module to the right of the steering column.Any good guesses? Thanks Russ.
------------- BigDog
Posted By: Geeque
Date Posted: December 12, 2005 at 5:09 PM
Its behind the drivers side dash, wires facing towards back of vehicle, look for a box connected to the firewall way up. Wire color is correct, pin location is right and connector.
------------- Gary Kline
MECP Master Technician
Posted By: gus1
Date Posted: December 12, 2005 at 5:12 PM
Weird....
Never had a problem using the light green in the far right plug of the BCM that is directly under the steering column on any GM truck platform pre 2003.
It will show negative when the key is turned to unlock in the driver's door cylnder.
Gus
------------- Wherever I go, that is where I end up......
Posted By: gus1
Date Posted: December 12, 2005 at 5:22 PM
Weird....
Gus
Date Posted: December 12, 2005 at 5:29 PM
I'll get it back in a day or two and I'll try it again,Russ
