2006 Dodge Grand Caravan Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68267
Printed Date: May 11, 2024 at 7:28 PM
Topic: 2006 Dodge Grand Caravan Remote Start
Posted By: mugpar
Subject: 2006 Dodge Grand Caravan Remote Start
Date Posted: December 13, 2005 at 8:22 AM
Has anyone done a remote start on a 2006 dodge caravan yet? Do you know if it's the same wiring as the 2005 Dodge Caravan? Thanks
Posted By: Geeque
Date Posted: December 13, 2005 at 10:30 AM
Should be the same, real pain in the neck!!!!!!!!!!!
------------- Gary Kline
MECP Master Technician
Posted By: Ravendarat
Date Posted: December 13, 2005 at 10:41 AM
Ya I did one a couple days ago. Same as the 2005
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: mugpar
Date Posted: December 13, 2005 at 1:15 PM
How come it's such a pain?
Just wondering cause I have to do one this weekend.
Posted By: NowYaKnow
Date Posted: December 13, 2005 at 4:56 PM
Walk in the park..
- 1 Ignition (pink/white)
- 1 Starter (yellow)
- Power at the top of the BCM or the battery.
- Parking lights (WHITE/ brown, positive) and brake in the drivers kick (WHITE/ tan)
There's your basic start..
Mike
Posted By: Mike M2
Date Posted: December 13, 2005 at 4:59 PM
There's another starter wire that is a negative 5 wire needing a resistor. Not an easy car, but that terrible either....
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: December 13, 2005 at 5:05 PM
I don't think you need the 180 ohm through the 2nd starter wire anymore. Do it if you want to I guess, but I know it works fine on the newer ones without it.. I tested this pretty thoroughly and couldn't find any use for hooking up the 2nd starter anymore. Anybody else play with this?
Mike
Posted By: OhioMike1101
Date Posted: December 13, 2005 at 7:50 PM
Mike
I did an 05 T&C yesterday I grabbed 12 volt from IGN harness 1 IGN 1 Starter (+) I used the 2nd Starter also with 180 resistor (-) brake was at the brake switch I used a combo data bypass that did locks and power sliding doors. Pretty simple except that darn airbad at the knee bolster that kept me away from the IGN harness.
Posted By: autotech mobile
Date Posted: December 13, 2005 at 8:27 PM
I do tons of these for dealerships. After a few their not bad. Personaly I've found that I do have to use the 2nd start with 180ohm or vehicle won't start. As far as the air bag goes I unplug it.
Posted By: Mike M2
Date Posted: December 13, 2005 at 8:59 PM
I've found that if you don't use the second starter it will not start always. It seems every 5th start or so....
Tech Manager
CS Dealer Services
Date Posted: December 14, 2005 at 1:11 AM
I found the same thing, wont always start without the second starter wire.
Posted By: mugpar
Date Posted: December 23, 2005 at 9:14 PM
I just finished a rs in a 2006 dodge grand caravan. I hooked up a relay to the headlights. I start the vehicle and the parking lights come on after about 10 seconds. Does anyone know why it's taking so long for them to turn on?
Posted By: Mike M2
Date Posted: December 23, 2005 at 9:21 PM
What kind of remote start? Most DEI alarms are made that way....
Tech Manager
CS Dealer Services
Posted By: mugpar
Date Posted: December 23, 2005 at 9:26 PM
It's a valet 561R.
Posted By: mobile1
Date Posted: December 23, 2005 at 9:47 PM
if you are using voltage sense instead of tach, this will happen. the parking lights only turn on after the Remote starter "knows" the vehicle is running. with tach it knows right away, voltage takes a little bit.
Posted By: mugpar
Date Posted: January 02, 2006 at 9:47 AM
Im actually using tach, not voltage sense, it's taking like 10-15 seconds of running, before the parking lights come on.
Date Posted: January 02, 2006 at 2:49 PM
I have had that happen before and have never been able to pin down the reason. I am guessing its probally an issue with the resistance though.
Posted By: HandCommand
Date Posted: January 02, 2006 at 7:12 PM
Mike
Chalk up another one for not needing a 180ohm resistor. I did a brand new 06 Caravan last week for a repeat customer ( ive done at least 5 for their family and relatives ). Not a complaint from them yet!
Yes, that KNEE AIRBAG kind of sucks, get used to it. I see more and more vehicles have them. This was even on a BASE model Caravan with no power windows or locks.
