2000 Lexus RX 300, remote start/keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68272
Printed Date: May 11, 2024 at 8:36 AM
Topic: 2000 Lexus RX 300, remote start/keyless
Posted By: Joe Neal
Subject: 2000 Lexus RX 300, remote start/keyless
Date Posted: December 13, 2005 at 9:45 AM
Any Help would be appreciated. Installing Remote Start & Keyless Entry...No Alarm Customer only has 1 Factory Key. Conflicting wiring??........One says I can do Door Lock / Unlock at Driver Kick & another says Only inside Driver Door. Also, info on site says Auto Lights will stay On after R/S?? THANKS in advance..........
Posted By: Geeque
Date Posted: December 13, 2005 at 10:21 AM
Sounds like you have it well under control, what do u really need? You need a key for the security bypass, it is a transponder system in that vehicle.
------------- Gary Kline
MECP Master Technician
Posted By: Joe Neal
Date Posted: December 13, 2005 at 10:43 AM
I need more Info.......... About: Headlites staying on after Remote Start times out? What Transponder to use, when Customer only has 1 Key? Door Lock / Unlock wires? Or any other Info about Installation in this car..........
Posted By: JWorm
Date Posted: December 13, 2005 at 11:42 AM
You can use a PKT from bypasskit.com
They are an easy company to work with. Minumum order is only 2 bypass modules. Shipping is $4.99 for ground or $9.99 for overnight. They have a vehicle selector at the top of their page where you put in the vehicle type and it gives you what modules work with it.
They also make a TOYDL that will do the doorlocks.
I think a 555x or 555F from DEI will also work.
Hook up the rearm wire from the remote start to the drivers door trigger wire. I have found you often need to use a relay to give it a stronger ground. You must be using a true door trigger wire. Pull the pin switch out and check the color of the wire, then find it in the drivers running board area. When the remote start shuts off it will pulse the door pin making the car think a door opened. The headlights should shut off right away, or a minute later depending on how the car usually acts.
If it has a factory alarm, you must hook up a ground when running wire to the keysense wire to prevent the alarm from triggering.
Posted By: Joe Neal
Date Posted: December 13, 2005 at 6:54 PM
Thanks for the Help............ I'm supposed to get the vehicle friday, .....I am still gonna look for more info
Thanks again
Posted By: g4mx
Date Posted: December 13, 2005 at 8:35 PM
i already install RX300/330 before .lock / unlock wire under the driver kick panal.(grey / Brown) auto start u must join u extra relay to join it ,b.coz this car have 2 ign wire n 2 starter wire ...ign1 purple(BIG),ign2 green-starter1 blue(Big), stater 2 white
