Trunk Release With DEI Valet 561R
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68477
Printed Date: February 26, 2026 at 8:00 PM
Topic: Trunk Release With DEI Valet 561R
Posted By: tbone587
Subject: Trunk Release With DEI Valet 561R
Date Posted: December 15, 2005 at 9:36 PM
I installing a dei valet 561r in my friends 2002 Ford Focus.  Tomorrow I am installing some actuators to convert his manual locks into power door locks.  I also want to hook up the trunk release button while I am at it.  From the diagram found on this site it appears that the trunk release button on this car is a - signal.  Am I able to use a relay some how to hook into the RED / white auxilary wire to pop the trunk with the aux button, or do i have to get a whole trunk release solenoid because of the negative signal being sent out by the button.
Posted By: mo12v
Date Posted: December 15, 2005 at 9:53 PM
Some Installers wire Direct, but I am sure your instructions recommend a Relay.
Sometimes the 250ma output is not enough & you risk damage........
MO
Posted By: tbone587
Date Posted: December 15, 2005 at 10:29 PM
Can someone give me a relay diagram for when the trunk release button is a negative (-) signal?
Posted By: mo12v
Date Posted: December 15, 2005 at 10:35 PM
SPDT Relay
PIN 87 = Trunk wire
PIN 87a = XX
PIN 30 = GROUND
PIN 85 = Negative  Output from 561r
PIN 86 = Constant 12 volt ( + )
MO
Posted By: KPierson
Date Posted: December 15, 2005 at 10:45 PM
Pin 85 - RED / white wire from alarm
Pin 86 - 12vdc
Pin30 - Trunk release wire in car
Pin87 - Ground
Kevin Pierson
Posted By: tbone587
Date Posted: December 15, 2005 at 10:49 PM
Hmm, how come KPierson and mo12v said different things?  Will both work if the trunk release button is sending a - signal, or is one of you incorrect?  I appreciate the fast responces by the way..
Posted By: KPierson
Date Posted: December 15, 2005 at 10:52 PM
Another one of my posts mysteriously eaten by the monster that is the12volt.com.....   :)
Kevin Pierson
Posted By: KPierson
Date Posted: December 15, 2005 at 10:59 PM
Pins 85 and 86 are interchangeble, as they are non polarized coil wires.  As long as you have a ground on one side and 12vdc on the other the relay will work.
Pins 30 and 87 are interchangable IF you are using the relay as a SPST NO relay, as we are.  These are basic switch contacts (connected when engerzied, disconnected when not energzied).
Kevin Pierson
