REMOTE START
Battery RED (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN (+) IGNITION SWITCH HARNESS
Ignition 2 GREEN (+) IGNITION SWITCH HARNESS
Accessory 1 VIOLET (+) IGNITION SWITCH HARNESS
Starter 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Type EWS II
Anti-Theft Descript AN RF SIGNAL ACTIVATED SYSTEM
Key Sense BROWN / GREEN (-) IGNITION SWITCH HARNESS
Tachometer BLACK / YELLOW (AC) BEHIND INSTRUMENT CLUSTER IN HARNESS
Speed Sense BROWN / RED (AC) IN HARNESS FROM GAUGES
Parking Lights BLACK (-) AT VEHICLE LIGHT SWITCH
Brake Lights BROWN / GRAY (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights BLUE / YELLOW (+) DRIVER KICKPANEL IN HARNESS TO REAR OF VEHICLE
Horn BROWN / RED (-) AT STEARING COLUM
Headlights-Lo YELLOW (+) AT VEHICLE LIGHT SWITCH HARNESS
Parking Brake BROWN / GRAY (+) ATSWITCH ABOVE BRAKE PEDAL
Trnk Release GRAY/BROWN (-) AT TRUNK RELEASE SWITCH IN DRIVER KICKPANEL
SECURITY
All Door Trigger BLUE/RED (-) AT MAIN DOMELIGHT
Trunk Trigger BROWN / WHITE (-) AT SWITCH IN TRUNK
Hood Trigger VIOLET/GREEN (-) AT SWITCH UNDER HOOD
Alarm Disarm DISARMS WITH UNLOCK
Alarm Arm ARMS WITH LOCK
DOOR LOCKS
Power Unlock BLACK/ WHITE (+) IN DRIVERS DOOR AT SWITCH
PowerLock BLUE/RED (+) IN DRIVERS DOOR AT SWITCH
