Tach at Ignitor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6991
Printed Date: May 02, 2024 at 8:12 AM
Topic: Tach at Ignitor
Posted By: John Doe
Subject: Tach at Ignitor
Date Posted: December 22, 2002 at 9:42 AM
I have a 94 Toyota T100 and am installing a remote starter and the wire diagram I have says the tach wire is Black at the ignitor. How do I identify the ignitor? Is it the same as the distributor, or where could zi look for it so I dont have to test every black wire in the engine. Thanks a lot ------------- JD
Posted By: egtalon93
Date Posted: December 22, 2002 at 9:46 AM
try a different spot here TACHOMETER|----gray/red or black , check conn *1 *1 The check connector is located on the front passenger inner fender well next to the underhood fuse box.
Posted By: themagicone
Date Posted: December 22, 2002 at 11:21 AM
This 93/94 toyota suck for tachs, took me 45mins to find one on a 93 lexus sc400, just about when i was going to give up i found a wire on the front drivers side of the engine, its a coil of sorts and has a spark plug wire going off it, two wires run to it and one is a tach
Posted By: John Doe
Date Posted: December 22, 2002 at 2:29 PM
I found it at the check connector like egtalon93 suggested, it tested at about 8 volts AC, but it worked like a charm, It actually read around 5v AC on my cheap $25 DMM, and 8 on my expensive one, but it was good enough to work, so it was good enough for me. Thanks
------------- JD
